HELP! Throttle hesitation in any gear
Old Jan 11, 2014 | 03:51 PM
  #41
350slug's Avatar
350slug
The relearn is three steps and on the final one make sure u meet all the requirements
Old Jan 12, 2014 | 03:09 AM
  #42
myfirstzcar's Avatar
myfirstzcar
^ True, or you can unplug the battery for 24 hours and everything will do what it's supposed to when you start it back up again.....if nothing's wrong.
Old Jan 12, 2014 | 04:59 PM
  #43
solidsnake's Avatar
solidsnake
I will try the unplug for 24hrs. I tried the three step relearn but damn it it's hard to get right with the time even with a stopwatch. The SES light is on now. Grrr!
Old Jan 13, 2014 | 01:14 AM
  #44
myfirstzcar
LOL, I tried the stopwatch method, but ended up learning how to count instead. I have to do the ecu reset quite often at work. Try training yourself to count perfect seconds, and remember to wait at least seconds during that time after the 5 wot in 5 seconds or less.
Old Jan 13, 2014 | 04:55 AM
  #45
350slug's Avatar
350slug
It also worked better for me counting rather then using a stopwatch
Old Jan 13, 2014 | 02:00 PM
  #46
Spike100's Avatar
Spike100
I agree that counting (one thousand one, one thousand two...) is best. It's difficult keeping track of this watching the sweep hand on any watch. --Spike
Old Jan 13, 2014 | 06:58 PM
  #47
solidsnake's Avatar
solidsnake
I am going to try it before I give in and goto the dealer to have them do it. From what I am reading they will rape me without lube for what would probably take 10minutes to do.
Old Jan 14, 2014 | 01:58 PM
  #48
zakmartin's Avatar
zakmartin
Was the battery connected when you pulled the throttle off to clean it? You're probably going to need a new one if that's the case because it's now a paper weight. I hate the trolling that's been going on in the maintenance forum over the past couple years, but I have to agree that there's so much bad advice on this thread, it's painful to read. Do a search for throttle body removal and you'll see some serious horror stories from people who didn't follow the procedures laid out in the FSM.
Old Jan 14, 2014 | 02:24 PM
  #49
solidsnake's Avatar
solidsnake
I admit I did not disconnect the negative. BUT I did not remove the throttle body. All I did was remove the intake tube and clean the inside. Didn't disconnect the TPS or anything. Just the intake tube to get to the inside of the TB.
Old Jan 14, 2014 | 03:07 PM
  #50
350slug's Avatar
350slug
Just trying to be helpful, youll notice I referenced the page # in the fsm.
Old Jan 15, 2014 | 01:26 AM
  #51
myfirstzcar
That's a crock right there. I've taken the TB off my Z 3 times, off my Titan once, and off Nissan lift trucks hundreds of times....all with the battery connected. Never had an issue.
This thread is full of bad advice you say? Where's your advice?
Old Jan 15, 2014 | 03:46 PM
  #52
Spike100's Avatar
Spike100
I agree. There is more argument here than simply bad advice.
Of course there will be “guessing” and debating about the main issues in this case because it’s complicated with possibly (likely?) synergistic causes.
--Spike
Additional Comment: "That's a crock right there." is harsh and I suppose even inflammatory. I get it, but you may have earned an adversary.
Old Jan 15, 2014 | 04:31 PM
  #53
travlee's Avatar
travlee
Master
if it is idling high the butterfly (or whatever you want to call it) inside the throttle body might be lodged open a little by something......
Old Jan 15, 2014 | 06:56 PM
  #54
solidsnake's Avatar
solidsnake
^you may be correct. I am going to check it tonight before I take it to UpRev.
Old Jan 16, 2014 | 01:33 AM
  #55
myfirstzcar
--Spike
I don't care. I just think it's ridiculous for anyone to think that a TB would be junk by simply unplugging it.....By "anyone", I mean the place where zakmartin read that info.
Nothing personal to you Zak.
Old Jan 16, 2014 | 02:56 PM
  #56
solidsnake's Avatar
solidsnake
PROBLEM SOLVED. Throttle body cleaned, caused Idle to be jacked up. Went to UpRev and got it fixed with the computer the dealer uses ($65). Car running smooth as a baby. I would have never guessed to clean the TB but it makes sense since when the issue was present I didn't have any SES lights. Thanks everyone for the input.
And for the record. Cleaning it without unplugging the negative to battery doesn't ruin your TB. That makes no sense at all.
Old Jan 16, 2014 | 05:50 PM
  #57
350slug's Avatar
350slug
Glad u got it figured out. That funk in the tb is a beetch.
Old Jan 17, 2014 | 03:18 AM
  #58
myfirstzcar
That's good to hear! Maybe I'll clean mine this spring.
Old Jan 17, 2014 | 04:32 AM
  #59
350slug's Avatar
350slug
It's totally worth it. My G had 100k on it and threw the high idle code. It took me a bit to figure it out. My Z has 63k and I installed a spacer and decided to clean my TB as I was there anyways. The Z was way dirtier than the G.
Old Jan 17, 2014 | 05:57 AM
  #60
myfirstzcar
I had mine off about 2 years ago, so maybe it just needs a good looking at....car has no symptoms or issues.
