2006 rear wheel bearing/hub
Old Dec 14, 2013 | 06:15 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Originally Posted by l2frankie
i had called around to verify myself and yea sounds legit to me. only problem is i noticed the dust pan scraps my rotors when i drive. ( squeaking sound) when i push the dust pan back the noise goes away for about a minute. lose dust pan? i doubt these things can go bad right?
You need the brake backing plate (dust pan) for proper clearance on ABS. You could cut them off, but do not remove them. It sounds like you should check the run-out on your rear rotors, as they might be warped enough to cause a squeak when the brakes are not engaged.
Old Dec 14, 2013 | 06:51 PM
Italianjoe1's Avatar
Italianjoe1
Yeah something isn't right, possibily something in the brakes touching. Have it looked at.
Old Dec 14, 2013 | 08:11 PM
l2frankie's Avatar
l2frankie
i def have to get it checked out the squeak is pissing me off. ill see if this monday i can either take it apart myself or drop it off at this guys place. hope its nothing crazy
3vilbunny
Jul 18, 2017 05:10 PM
