Changed valve cover now car won't stay running.
Old Dec 26, 2013 | 04:20 AM
kaedachef's Avatar
kaedachef
Default Changed valve cover now car won't stay running.
Yesterday I replaced the drivers side valve cover after destroying the threds for my coil on the old one. Like an idiot I didn't remove the negative terminal and disconnected the throttle body plug when i removed it. Now the cars all buttoned up and starts then dies 2 sec later. I tried the relearns and left the negative terminal off over night not sure if i should have waited the full 24 hours. All hoses and connectors are tight. Any help would be greatly appreciated since this is my daily driver and i need my car to get to work. Thanks in advance.
Old Dec 26, 2013 | 09:24 AM
tcode's Avatar
tcode
I really doubt that's electrically related. Check all vacuum hoses and intake manifold seals.
Old Dec 26, 2013 | 11:00 AM
Jennifer 2's Avatar
Jennifer 2
Kaedachef, search this site or google for the throttle relearn procedure.
Old Dec 26, 2013 | 11:55 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
did you knock the cam sensor connectors loose?
TB shouldnt be an issue.........its only a set of pots and 2 motors. I have completely disassembled mine without issue.
Old Dec 26, 2013 | 12:08 PM
SQuaLZ's Avatar
SQuaLZ
As tcode said I would check to make sure you have no vacuum leaks anywhere.
Trust me, I have done jobs like this and have a problem and am so sure I reinstalled everything right, then I find a part I missed or something I knocked loose.
Old Dec 26, 2013 | 12:15 PM
kaedachef's Avatar
kaedachef
The intake manifold seals were good checked as I was reinstalling it. Everything that was unplugged was reconnected tight and only hose that was disconnected was water and the one to the intake tube. Gonna get a scanner in a few to see what code its giving me.
Old Dec 26, 2013 | 01:12 PM
kaedachef's Avatar
kaedachef
Ok just checked the codes nuthin thrown except abs abnormal battery voltage c1109. Nuthing to do with my problem. I checked the bolts on the upper manifold and was able to turn them all even though I used a torque wrench and did it in the order i was supposed to. Which means that the bolts on the lower might not be tight enough. Could this be the problem?
Old Dec 26, 2013 | 01:14 PM
kaedachef's Avatar
kaedachef
Also i put in the iridium IX plugs and didnt mess with the gap as some people have said not to. Could this be the problem?
Old Dec 26, 2013 | 05:42 PM
kaedachef's Avatar
kaedachef
Necermind. Friggin maf was on backwards. Was starin at the fsm and the arrow kept pointing down do thats the way i put it in. I should know better when last year i had the same problem. Haha. Thanks guys for trying to help me though. I appreciate it.
allmycarsdie
May 13, 2016 04:38 PM
May 12, 2016 07:42 PM
Brantwilliams13
Sep 16, 2015 05:03 AM
smithmt3
Sep 11, 2015 08:25 PM
Darkspy
Sep 7, 2015 09:09 PM
