Extreme power loss, rough idle. Help!
Old 01-02-2014, 06:34 PM
EthanF
EthanF's Avatar
Right now I'm running 225/55's on my 17's all around so I don't think that can be it. And to add to the confusion after driving to the gas station and filling up before the dry gas, it wouldn't start!!! After a quick jump from a nice old man it fired right up, but still threw me off how that happened...
Old 01-02-2014, 07:00 PM
Spike100
Spike100's Avatar
^^ Your tire sizes are good. --Spike
Old 01-03-2014, 12:10 AM
myfirstzcar
myfirstzcar's Avatar
Yeah no reason to suspect a tire issue, as long as the tires are the same size or the rears are slightly larger.
Old 01-06-2014, 05:42 PM
EthanF
EthanF's Avatar
So all was good until today in -10 degree weather it bogged down, gave me a SES which read as both front 02 sensors. Cleared the codes, reset the cry and it was perfect the rest of the way home. WHAT THE EFF?!?! If they were truly the problem it should still have issues after the reset, no? I'm beginning to think my car just doesn't like the cold....
Old 01-07-2014, 12:39 AM
myfirstzcar
The ecu reset will reset the rediness monitors, which means it may not detect a problem right away. both O2 sensors throwing codes, I would look for a lean condition being caused by something.
Old 01-07-2014, 08:38 PM
EthanF
EthanF's Avatar
And finally I have some codes to work with!!! P0321, P0152, P0300, and P0158! Which if I'm getting this right is that I have a misfire! Not sure where to go from here...possibly a bad coil pack/injector? :/
Old 01-08-2014, 01:16 PM
myfirstzcar
Random misfires are most likely to be caused by a fuel delivery issue, but there are many other possibilities.
Old 01-11-2014, 12:02 PM
EthanF
EthanF's Avatar
Cleaned the (very dirty) throttle body today, did all the resets and got the readings off of the front O2 sensors....both read 1.3 volts!!!! If I'm not mistaken that's really really rich :/ Now I'm even more confused
Old 01-11-2014, 02:19 PM
myfirstzcar
Did you let it warm up and go into closed loop before you took the readings?
Old 01-11-2014, 05:01 PM
EthanF
EthanF's Avatar
Yep! Even while cruising on the highway it was a pretty steady reading of 1.3v from the sensors
Old 01-12-2014, 03:07 AM
myfirstzcar
That sucks. FYI, if you have a coil pack issue your check engine light will flash. I think I'd dismiss that possibility for now.
Old 01-16-2014, 08:51 PM
EthanF
EthanF's Avatar
Swapped maf sensors with a friend today....still rough idle and still the ses light comes on showing both o2 sensors are reading high voltage. Could they booth be the root of my problem? I'm running out of ideas
Old 01-16-2014, 08:52 PM
EthanF
EthanF's Avatar
And the 03003 misfire I should add too :P
Old 01-17-2014, 03:27 AM
myfirstzcar
What are the rear O2 sensors reading? I have a sensor getting bad on my truck, the fuel trims are even, rear sensors are even, one upstream sensor reads a bit high. Fortunately, it's still within it's range and there's no worries at this time.
Old 01-19-2014, 05:14 PM
EthanF
EthanF's Avatar
both upstream sensors are reading a pretty steady 1.3v
Old 01-20-2014, 12:56 AM
myfirstzcar
And the downstream sensors?
Old 01-20-2014, 02:45 AM
350Zdj
350Zdj's Avatar
Maybe you should check if all plugs are firing. It could be just bad coilpacks.
I had dead coilpacks before and it made the car idle rough and lost a huge amount of power. It also caused CEL and a few other errors to show up.
Old 01-20-2014, 07:16 AM
  #38
EthanF
EthanF's Avatar
Downstream sensors are also reading 1.3v due to test pipes I'm assuming. Coils should be good if I checked them right
Old 01-20-2014, 03:06 PM
  #39
myfirstzcar
Ok, all of your sensors are reading 1.3v correct? Your car is extremely rich. I don't believe they can go past 1.3v, but I may be mistaken there.
Old 01-20-2014, 03:14 PM
  #40
myfirstzcar
I would also rule out the misfiring completely, since running extremely rich will cause the ecu to detect a misfire. Something is causing this car to dump fuel, and I'm thinking it's intermittent as well.
Quick Reply: Extreme power loss, rough idle. Help!
