Door Issue
Old Jan 7, 2014 | 06:24 AM
radiocrash's Avatar
radiocrash
Default Door Issue
Let me start this off by saying it was 1 degree outside this morning so I'm assuming that's what caused this.
I went out to start my car this morning, as I usually do, and went inside. When I came back out, I noticed the door wasn't closed all the way...like it wasn't closed with enough force and was caught on the hinge but not shut. I hop in and go to close the door behind me. It won't. It literally won't even catch it at all. No grab, it was like I was holding the handle so it wouldn't close.
At this point I couldn't wait anymore or else I'd be late to work, so I hit the lock switch while it was closed and it stayed closed. Not all the way though, like I said before. I wasn't able to reopen the door and the lock switch was freaking the f*** out and making weird noises. So I quickly hit unlock and the door opened. I was able to close it all the way, but now it won't open even if the doors are unlocked. The passenger side door is fine.
Anyone else have this issue?
Sorry for the essay. TLDR; door is a piece of sh** halp.
Old Jan 7, 2014 | 06:55 AM
Syner's Avatar
Syner
I had a latch flip on a part car. Not fun.
Old Jan 7, 2014 | 07:05 AM
radiocrash's Avatar
radiocrash
Considering I have a stomach bug and it's fuhreeeezing I guess I'll just go to the stealership and instantly regret it. Or maybe it'll magically start working
Old Jan 7, 2014 | 07:25 AM
KornerCarver's Avatar
KornerCarver
Can you get your car into a garage? If so, put an electric heater on it and see if it starts working once you get everything warmed up.
Old Jan 7, 2014 | 07:28 AM
Syner's Avatar
Syner
It's worth a shot. Hopefully it's just the weather seal. But that wouldn't explain the door not closing (unless there is a ton of water inside the door?).
JERZ350's Avatar
JERZ350
Is it your window? Z windows are supposed to go down 1/4 inch or so to allow for the door to close easier / air pocket. 3 degrees, windows wont budge so harder to close. Mine I had to pull the door slightly harder to get it to seal because the window wouldn't do it's thing.
Old Jan 7, 2014 | 07:41 AM
radiocrash's Avatar
radiocrash
Don't think so. As I was driving with the door not closed all the way, the window kept trying to close that last gap like it does when it shuts normally. The computer kept thinking the door was shut and reopening, so the interior light was turning on and off, same with the dash alert for having an opened door, and the window was going up and down. I eventually just cracked the window open so it would stop trying to close.
Old Jan 7, 2014 | 11:53 AM
DarkRain0660's Avatar
DarkRain0660
Mine did it the first time the temp got down below zero up here in watertown NY. I left it alone for a while til the temp got a few degrees warmer and pulled the battery cables off for a half hour then beat on door with my hand under the handle and it opened for me. I'd if it'll work for you but it's worth a try
Old Jan 7, 2014 | 01:40 PM
radiocrash's Avatar
radiocrash
To my pleasant surprise I walked out of work today to find that the door was magically working fine.
Hmm...to be continued.
Old Jan 7, 2014 | 01:44 PM
350ZZJoe's Avatar
350ZZJoe
This is the 3rd winter I've driven my Z. This has happened to me every winter. Atleast once during the first time the temps go below freezing and usually one more time during the year.
Funny enough, my second installment also happened this morning going to work just like you! I'm 6 foot 5 and had to crawl through the Z out the passenger door when I got to work. Leaving work (30mins ago), everything was fully functional and fine.
What I have done every year is liberally sprayed some sort of water displacing lubricant into the lock from the keyhole as well as the latch that actually keeps the door shut. If I did this more regularly throughout the winter I am sure it would work even better.
Oh and also, 1 degree? It felt like -35* F this morning here with the windchill.
EDIT: Haha! I just see you also left work and it was all fine. I didn't see you post that right before me lol
Old Jan 7, 2014 | 02:00 PM
zamfield's Avatar
zamfield
Same issue here... Passenger door opened no problem. Had to get in the passenger side, lean over and hit the inside of the drivers door - it opened!
The wife then asked why I didn't just let the car warm up and it would have melted and opened.
I hate her sometimes!! ;-)
Old Jan 8, 2014 | 07:20 AM
radiocrash's Avatar
radiocrash
Lmao that's really weird. I'm gonna try your technique with spraying some lube...thanks!
my reaction to statements like that
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
