Hard clunking sound when turning or rapidly stopping.
That's chill dude, thanks. I'm gonna be brining the car to my buddies lift. See what's going on I'll post pictures even if there's nothing there to see. Be back in a couple hours.
OK, Stupidity or just sheer genius right here. Just got done peeking my head under my car. Looked at all links possible from closest to tire 1-4 the 4th bushing/bolt lower control arm looks like this. I'm gonna tighten it now. As you can tell from the positioning nut itself there's a background shadow projecting onto the bracket itself
Unfortunately, the noise has not gone away. I'm gonna see what else is loose and get some loctite on them "IF" there is any "finger tightened" nuts left... Or it could be the Arm hasn't set right since tightening. Gonna see if I can continue to tighten it after the snow settles. No damage though
Someone's had that suspension apart before, which means they probably put it back together with the car up in the air. Tightening the lower shock bolt (on the control arm) with the car up in the air can cause that bushing to rip.
Should I take the links out to see the bushings better? Makes a lot of sense, still learning the suspension on this car. I'm the second owner, the car had very poor maintenance.
The fourth TransLink that connects to the sub frame wasn't fully tightened. Make sure to have the car on all four lift so all four tires are resting on a full load and take a impact gun to it. If that doesn't help you may need to replace your whole steering rack.... "If" the car wasn't well maintained. Digging the metal gear solid reference.
Justin100
Nov 29, 2015 03:58 PM
