Help please!!!
Old Jan 17, 2014 | 04:11 PM
zetosan's Avatar
zetosan
Default Help please!!!
So yesterday my fan wouldn't turn off. So today i added a little of distilled water in the reservoir because it was a bit low and i went on a drive, didn't drive too hard but a little bit hard. Then my fan kicked in and then the coolant gauge started to spike up then it went back to normal and so i check under the hood and there were some leakage by the thermostat housing. What do you guys think this is? bad thermostat? bad radiator? bad coolant?
Old Jan 17, 2014 | 04:31 PM
RMichael's Avatar
RMichael
So, you have a coolant leak?
Old Jan 17, 2014 | 04:46 PM
zetosan's Avatar
zetosan
I don't know what it is. The radiator just would not turn off until I turn the car off. And I don't know what the coolant leak oon the thermostat was.
Old Jan 17, 2014 | 05:06 PM
travlee's Avatar
travlee
Master
the radiator itself doesnt run, assuming you are talking about the fans that would kick on when the temperature rises kicked off by the thermostat. i would start by changing it out
Old Jan 17, 2014 | 05:27 PM
zetosan's Avatar
zetosan
Yes that's exactly I meant. The fan keeps on spinning and spinning. So should I change thermostat? My coolant looked pretty dirty do you think it could've cause the thermostat to clog?
Old Jan 17, 2014 | 05:57 PM
350zchad's Avatar
350zchad
miles on car?
as said most likely thermostat
Old Jan 17, 2014 | 06:13 PM
zetosan's Avatar
zetosan
Originally Posted by 350zchad
miles on car?
It's an 05 with about 77000 miles
Old Jan 17, 2014 | 09:36 PM
terrasmak's Avatar
I would start with a new thermostat, fix the leak and a good flush. See what happens and go from there.
