Low Oil Pressure! Help!
Old Feb 2, 2014 | 09:01 PM
CaychO's Avatar
CaychO
Default Low Oil Pressure! Help!
Hey guys, I just recently purchased a 2008 nissan 350z with 60k miles from a Toyota/Scion dealership, and I took it to a mechanic before I purchased it, and the mechanic said it looked clean and drove well....DOH! Unfortunately I noticed that the oil pressure drops to about 9-10 psi at idle after warm up. It just doesn't seem right...and it's only been a little over a week. It's generally 5-20 psi lower than the reccomended psi at every rpm level. I don't have any oil lights or check engine lights coming on and everything seems pretty sound other than this issue (it's really been bugging me). Also, it has a fresh oil and oil filter change and the oil is certainly not low.
Anyways, the good news is that I have a 60 day warranty and it has only been a week, and I also have documented evidence from a mechanic I took it to that it read 9-10 psi at idle and lower than recommended at 2000 and 3000 rpms as well (My gauge is reading correctly, so take that out of the equation). What do you guys recommend I do here? Is this sufficient enough to make a claim and get something fixed here? I'm kind of afraid that they will somehow f me over....Sorry, I'm just a little stressed and need some advice!
Thanks guys!
Old Feb 3, 2014 | 03:37 AM
BY350z's Avatar
BY350z
Could be the Oil pressure sensor
Old Feb 3, 2014 | 04:55 AM
travlee's Avatar
travlee
Master
at idle mine hovers right above the lowest line, always has (also an HR). i havent had any issues in the two and years i have had it
Old Feb 3, 2014 | 08:17 AM
CaychO's Avatar
CaychO
Okay, another problem I have is when I push the clutch in on start up (especially on cold days) the engine revs like 300-400 rpms up. Does that happen to your too? After it warms up its fine
Old Feb 3, 2014 | 08:22 AM
travlee's Avatar
travlee
Master
like it revs high for a min and then drops back down.... if so yes mine does that also
Old Feb 3, 2014 | 08:35 AM
Syner's Avatar
Syner
Typical behavior, you're scaring yourself into thinking there is a problem.
Old Feb 3, 2014 | 09:15 AM
CaychO's Avatar
CaychO
I know it's probably nothing mainly I'm worried about low oil pressures because I heard it can mean some bad things....
Old Feb 3, 2014 | 09:17 AM
Syner's Avatar
Syner
Did you check the oil level?
I've found oil PSI @idle is much lower in 350Z's than other cars I've owned.
Old Feb 3, 2014 | 09:21 AM
CaychO's Avatar
CaychO
Oil level is good, what are you lookin at?
Old Feb 3, 2014 | 09:32 AM
Syner's Avatar
Syner
What do you mean "what am I looking at?"
Old Feb 3, 2014 | 09:49 AM
CaychO's Avatar
CaychO
As in what is YOUR oil psi at idle, haha.
Old Feb 3, 2014 | 09:55 AM
Syner's Avatar
Syner
Oh haha...
I don't remember the exact numbers, mine is put away for the winter. If I remember correctly, it's 10-15 at a warm idle.
Old Feb 3, 2014 | 10:23 AM
CaychO's Avatar
CaychO
Oh haha...
Ah okay, this is good news hah
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
