Redline or OEM Trans Fluid?
Old Mar 31, 2014 | 09:27 PM
Shawns'Z's Avatar
Shawns'Z
Default Redline or OEM Trans Fluid?
Ok I've done a bit of poking around on here and I can't seem to find a definite answer, unless it comes down to a preference. My 04' has 130k on it, and I don't know the last time the tranny fluid has been changed(I've put 10k on it). I have the 2nd gear grind once in awhile(if I'm shifting fast and hard) every other gear is fine. All gears are fine if I'm puttin around, except for a LITTLE notchyness. ANYWAY, the threads I found were about a year old and it seemed everyone was split about 50/50 whether they preferred Redline or Nissan tranny fluid. Speaking from experience with both, who likes what and how long have you been running it?
Old Apr 1, 2014 | 06:46 AM
Z1Motorsports's Avatar
Z1Motorsports
We recommend the redline MT85 or Amsoil MT85 for smoother shifts
Jon
Old Apr 1, 2014 | 06:47 AM
samsniss350z's Avatar
samsniss350z
I prefer the OEM in mine. It's had OEM in it for 75k miles with no problems.
Old Apr 1, 2014 | 07:03 AM
92K1500's Avatar
92K1500
I changed the oil in mine around 90-100k miles. I used redline MT85 and I couldn't tell any difference.
Old Apr 1, 2014 | 08:02 AM
dkmura's Avatar
dkmura
General & DIY Moderator
I use MT85 in my street 350Z with 92K on it and wouldn't go back to the OEM fluid. I also use the same product in my SCCA Z33, which had been campaigned over six years. The heat and stress of competition have proved its value to me.
Old Apr 1, 2014 | 08:30 AM
TuckerE36's Avatar
TuckerE36
I had the same debate a month ago, ended up just going with OEM fluid. I don't track or drive my Z hard too much, oh and Nissan sold it to me for $6 a quart.
Old Apr 1, 2014 | 01:38 PM
Shawns'Z's Avatar
Shawns'Z
So pretty well the difference between one or the other is how you drive your car? Seems like people that track, like the redline ,but people that baby the car like oem. I usually drive my car pretty spiritedly but nothing extreme, I guess if I get the redline I'll only be out about 50$ and a little time if I don't like it.
Old Apr 1, 2014 | 02:02 PM
92K1500's Avatar
92K1500
I don't track the car, and I definitely don't baby her. But as I said, I couldn't tell the difference. Sounds the same (still noisy as hell), shifts the same, and I don't have a trans temp gauge but I'm guessing the temp is the same.
Old Apr 1, 2014 | 03:57 PM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Motul
Old Apr 1, 2014 | 04:38 PM
myfirstzcar's Avatar
myfirstzcar
I switched to redline at about 40,000 miles and it felt like a new transmission after that.
Old Apr 1, 2014 | 04:47 PM
taywan's Avatar
taywan
I did OEM GL-5 and Amsoil for rear end. Was going to do Amsoil in tranny but just did OEM. Felt better through gears and all. Recommended intervals are 30k I believe and may do motul or one of the others next time, will see.
Old Apr 1, 2014 | 05:32 PM
TuckerE36's Avatar
TuckerE36
OEM M/T fluid is GL-4 no?
Old Apr 1, 2014 | 05:36 PM
taywan's Avatar
taywan
Ya think that's correct. Sorry and been a while since I've swapped fluids.
Think gl5 was rear end
Old Apr 2, 2014 | 09:59 AM
marcster13's Avatar
marcster13
I'm a newer owner and had no shifting issues but didn't know how old the oil was so I changed it to Redline MT-85. The car when cold, kinda clunks into 2nd and sometimes 3rd gear. Once warmed up though I notice no shifting issues. Next time I change it I'll try OEM, that's assuming thats what was in it before. As for tranny noise it's loud but I believe thats due to the flywheel.
Old Apr 2, 2014 | 12:11 PM
92K1500's Avatar
92K1500
2nd is very common in the 6MT 350's. 5th will also be picky at times.
The trans is also just noisy at idle in neutral with the clutch out. There is nothing you can do about it.
Old Apr 3, 2014 | 05:20 PM
Shawns'Z's Avatar
Shawns'Z
No issue so far with 5th(knock on wood) 2nds my only gripe. It's embarrassing when you try to race a mustang and grind 2nd -.- anyway ill order some redline I guess and see how it does, if it gives me problems I'll buy some oem. Thanks guys.
Old Apr 4, 2014 | 04:39 AM
myfirstzcar
There's something about redline that clearly allowed my synchros to have more "traction", resulting in smoother shifting. It's a little picky when cold, great when warm.
Old Apr 6, 2014 | 06:42 AM
92K1500's Avatar
92K1500
You shouldn't be racing right after you start the car anyways....
If it's warmed up and still grinding try the redline. If it still grinds either drop the trans and rebuild it or start lifting weights so you can force it into gear harder to prevent any grind.
Old Apr 7, 2014 | 07:01 AM
SQuaLZ's Avatar
SQuaLZ
Just put in Redline MT-85 yesterday and I can say that it is a WORLD of a difference compared to the OEM fluid. My OEM fluid only had about 2k miles since Nissan rebuilt my tranny last summer and ever since then I was having some issues with 5th gear grinding and notchy shifting. After swapping the fluid yesterday, I can say my tranny is now super smooth, and no more 5th gear grind! It feels like a whole different tranny.
Old Apr 7, 2014 | 01:36 PM
myfirstzcar
That's what I said! I can't even imagine how mine was before, but I'm going to change it again this summer since it's been about 15,000 miles. After that I'll let 'er ride a while.
