Help locating Automatic Transmission drain plug
Old Apr 27, 2014 | 12:42 PM
LVZ's Avatar
LVZ
Default Help locating Automatic Transmission drain plug
I have a 2005 automatic transmission 350z enthusiast and need to drain and add new transmission fluid. I have the recommended S transmission fluid and transfer pump. My only question is where is the drain and fill bolts located on a automatic 350z? I looked at some videos for draining MT 350z but haven't seen anything on a Automatic 350z transmission.
Please help I'm ready to get this project started! Also I read you can use the same fluid for the transmission as the rear Diff?
Old Apr 27, 2014 | 01:34 PM
johndoesdamage's Avatar
johndoesdamage
Full is right behind the plenum tube coming up with a black cap near the firewall and the drain is black pan with a octagon flat looking bolt the pan is is squared.. You don't need a transfer pump I just filled it with a funnel and poured into the tube you need a skinny funnel though and the bolt holding down the black cap is 10mm.
Old Apr 27, 2014 | 01:35 PM
johndoesdamage
What part of Vegas are u at? I'll try posting u a pic of the fill for u
Old Apr 27, 2014 | 01:52 PM
LVZ's Avatar
LVZ
Thank you johndoesdamage I'm in mountains Edge, South west part of Vegas.
I easily located the drain and removed about 3.75 liters from it. still looking for the fill though. A picture would be very helpful johndoesdamage.
Edit:
Actually I think I just found it. Black circle cap being held down with a bolt. Says use Only J on it.
Thank you you have been a huge help!
Old Apr 27, 2014 | 01:55 PM
johndoesdamage
yea I got about 4 out and then filled drive around for about 1000 miles then drained another 4 and filled...
Old Apr 27, 2014 | 01:59 PM
johndoesdamage
Here ya go
Attached Thumbnails Help locating Automatic Transmission drain plug-image.jpg
07ZEKE
Aug 23, 2021 09:15 PM
burglapfd
Dec 6, 2020 01:04 PM
350z82
Oct 1, 2015 06:25 PM
35reilly
Sep 28, 2015 07:42 AM
