03 white smoke and fuel smell from exhaust
Old May 8, 2014 | 07:23 PM
cellkid's Avatar
cellkid
Default 03 white smoke and fuel smell from exhaust
Hello all!
I recently start to have a problem with my Z. Upon cold start up constant but light white smoke comes out of my exhaust with an unbearable fuel smell and when I say unbearable I mean eye burning need to run away smell! If I take it for a short drive the smoke stops but the heavy gas smell remains at all times and I can park it again and idle for hours and not see any smoke again till next cold start. I am not losing any water nor do I have any signs of water in my oil. I have seen a few similar post but not exact my smoking goes away as others remain throughout the duration of the motor running. Only mod I have is test pipes. Any ideas are welcome!
Old May 8, 2014 | 08:39 PM
bealljk's Avatar
bealljk
How long have you had your current tank of gas? I would cycle through at least a tank or two before you go chasing anything major. I had this issue but my car sat through approximately 15months with only a handful of drives and 3/4 tank of gas...I believe I had a ton of moisture build up. I siphoned the gas out (approximately 12gallons made it out)and put it in my pickup and it did the same thing...
if you are running cat-deletes than you will get some unburnt fuel - are these a recent modification??
Old May 8, 2014 | 09:47 PM
cellkid's Avatar
cellkid
Test pipes are fairly recent but since the install I have run three tanks and about 600 miles including a 300 mile trip. Before the test pipes it never smoked but did have an abnormally rich fuel smell to it. I was originally thinking I had a bad fuel injector but the white smoke is throwing me off. The car has 80k on it so I was considering changing the injectors anyway as a maint. Item and hopefully get lucky. Also I replaced the MAF and coolant temp sensor. The only other thing that has been done was I had my mechanic replace both valve cover gaskets at the same time he installed the test pipes. I wonder if some sort of air leak in the plenum could cause these problems?
Old May 9, 2014 | 04:47 AM
hellman_x's Avatar
hellman_x
Sounds like you are running rich but I'm not sure the TPs would throw the ecu off that much.
Old May 9, 2014 | 10:27 AM
cellkid's Avatar
cellkid
I agree. That's why I am stumped. I was going to replace the injectors anyway so I guess I will start there
Old May 9, 2014 | 08:47 PM
bealljk's Avatar
bealljk
I'm assuming you don't have any check engine lights...so that means your mechanic installed non-fouler-extensions on your O2 sensors - if not, you'd have a check engine almost immediately after starting up the car the first time.
Old May 10, 2014 | 03:20 AM
cellkid's Avatar
cellkid
I have no lights and my 02 sensors are still in place
Sleeper_Z
Sep 30, 2015 10:25 AM
