DashLights wont turn on?! after plugging/unplugging wires
Old May 27, 2014 | 08:05 PM
Julian<3hisZ's Avatar
Julian<3hisZ
Default DashLights wont turn on?! after plugging/unplugging wires
The dash lights (ie: fuel, speedometer, tachometer, engine temperature) as well as the Shifter lights (mine's an automatic) as well as the lights on the top 3 display (temp, oil level, and voltage level) all went out. I took out my center console to do some minor work, to do so I had to unplug the wire connecting the top 3 gauges, and I also unplugged the plug to the ACC controls. Both of these I plugged back in after finishing my work. I also permanently unplugged one of the bundle of wires that connects to the OEM radio unit unit because I have plans to replace it with a double DIN in the future anyway.
I restarted my car after hooking up the batteries again, but now the lights are all out.
I checked the fuse box, but cannot find the fuse that is labeled instrument lights
I am suspecting I messed up something when i pulled out that bundle of skinny wires connected to the OEM radio unit.
Other lights working fine (ie. head lights, dome light, parking lights, air conditioning, blinkers)
Please help? Thank you in advance
Old May 28, 2014 | 04:09 AM
bfrank757's Avatar
bfrank757
check the box that the A/C controls are connected to. ensure that none of those wires are loose. I believe one of them went to the stock radio. that box controls all of those gauges.
search for "Amplifier Control"
Last edited by bfrank757; May 28, 2014 at 04:14 AM. Reason: found more information
Old May 28, 2014 | 07:47 AM
Julian<3hisZ
The white box that is connected to the A/C? U think one of hte wires behind it is loose? ok i will check . brb
Old May 28, 2014 | 09:03 AM
vernors79's Avatar
vernors79
Try the fuse marked mirrors in the drivers side foot well.
Old May 28, 2014 | 09:58 AM
bfrank757's Avatar
bfrank757
yeah that "white box" controls the entire instrument panel.
and yeah check the "home link mirror" fuse
Old May 30, 2014 | 05:53 PM
Julian<3hisZ
OH YES!! the mirror fuse is indeed blown!! thank you! now i will try to get a replacement at part source tomorrow morning and replace it n tell u guys how it goes! thank u. But how did i blow it? when i unplugged the wires? so i dont repeat the same error in the future. Thank u!
Old May 30, 2014 | 07:37 PM
oldschool350z's Avatar
oldschool350z
Sometimes they just blow. Could have been a short or something of that nature.
Old May 31, 2014 | 07:45 PM
Julian<3hisZ
Hmm bad news guys ... I put in the new fuse. Started the car, nothing changed. The lights are still out and the side mirrors arnt moving. So i turned off the car and looked at the new fuse i just put in. It has also just blown as well. So i followed what you guys suggested to see if the wires plugged into the white box are loose. I found none of them are loose, all of them are in place. Attached are pictures. As you can see the white box at the bottom has all the wires in place, the radio box has one set of wires assembly pulled out.
Attached Thumbnails DashLights wont turn on?! after plugging/unplugging wires-20140531_233229.jpg   DashLights wont turn on?! after plugging/unplugging wires-20140531_233254.jpg
Old May 31, 2014 | 07:47 PM
Julian<3hisZ
What do you mean amplifier control??
Old Jun 3, 2014 | 07:10 PM
Julian<3hisZ
Still having trouble ... anyone else can help me??
Old Jun 11, 2014 | 10:24 PM
Julian<3hisZ
Bump~ still need help
Old Jun 12, 2014 | 05:41 AM
KornerCarver's Avatar
KornerCarver
Have you thought of trying to plug back in all of the wires that you un-plugged?
loudtoyz
Apr 6, 2023 04:52 AM
350Z_Al
Oct 29, 2020 07:44 PM
sherm
Apr 11, 2020 05:21 PM
nanotech
Oct 2, 2015 05:02 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
