All brake lights won't work
Old Jun 1, 2014 | 06:28 AM
MB33's Avatar
MB33
Default All brake lights won't work
Hey guys have an 04 roadster with 06 tail lights had them on for about 4 years now. Whenever i step on the brake all won't work. Fuse by battery is new. Now sometimes it will light up and then it won't work again. Anything else I'm missing or should check? Any help will be appreciated Thank you!
Old Jun 1, 2014 | 06:31 AM
Italianjoe1's Avatar
Italianjoe1
Check the switch down on the brake pedal, make sure it's releasing when you step down and not sticking.
Old Jun 1, 2014 | 07:09 AM
samsniss350z's Avatar
samsniss350z
Have you checked the connections from the lighting unit to the wiring harness?
Old Jun 1, 2014 | 08:23 AM
MB33's Avatar
MB33
The switch is directly behind the break pedal?
Old Jun 1, 2014 | 08:24 AM
MB33's Avatar
MB33
Yup i checked the connections and made sure nothing was loose on the tail lights.
Old Jun 1, 2014 | 12:56 PM
Italianjoe1
Haven't looked at the Z one but usually there is a plunger that sits against the pedal and will turn the lights on right when the pedal starts to go down.
Old Jun 1, 2014 | 10:57 PM
350Zdj's Avatar
350Zdj
Happened to mine before.
I got my bet on Italianjoe's advise. I'm pretty sure that's your solution right there.
Old Jun 2, 2014 | 03:06 AM
MB33's Avatar
MB33
350Zdj, how did you get it fixed?
Old Jun 3, 2014 | 06:22 AM
350Zdj's Avatar
350Zdj
There's something like a switch under the brake pedal. It was loose. We pulled it out, cleaned it a bit and it was back to normal.
Old Jun 6, 2014 | 04:25 AM
MB33's Avatar
MB33
Looks like I might need a new switch. I pulled out the plug then plugged it back in, work for a day then stopped working again. Any recommendations on where to buy a switch and any install info would help. Thanks!
Old Jun 6, 2014 | 04:31 AM
travlee's Avatar
travlee
Master
courtesyparts.com
Old Jun 7, 2014 | 04:13 AM
MB33's Avatar
MB33
Thanks!
Miguel Albanez
Oct 17, 2022 10:13 AM
JjL
East Canada
Jun 12, 2019 03:04 AM
dboyzalter
North East Marketplace
15
May 6, 2018 09:41 AM
Vigman
Nov 17, 2015 04:34 AM
Shane86
Sep 17, 2015 05:33 PM
