Oil Pressure in constant flux
Old Jul 23, 2014 | 04:17 AM
Sanchisimo's Avatar
Sanchisimo
Default Oil Pressure in constant flux
Hey, guys! Sorry if this is in the wrong section... I was hoping someone could help me out with this. I noticed the other day my oil pressure wasnt sitting where it should be. I have an 03 350z touring w/6sp. It seems as though any time i hit the pedal my oil pressure shoots up. It doesnt touch 120, but it doesnt stay below 100 either. Ive had a few issues with the car since i purchased it back in april, and im still working out the kinks. Does anyone have any suggestions as to how i could fix this situation? Or what the possible outcome may be if i dont rectify this soon?
Old Jul 23, 2014 | 04:25 AM
terrasmak's Avatar
If I understand what your saying, the oil pressure changes with RPM and it's not getting as high as it once did.
Google oil pressure and read just a little.
Old Jul 23, 2014 | 04:46 AM
Carfreak70852's Avatar
Carfreak70852
Check the oil level. As long as you are still getting a good amount of oil pressure, I wouldn't really worry too much about it. If it continues to drop, you may need to look into it more.
Old Jul 23, 2014 | 05:44 AM
cashmoney03's Avatar
cashmoney03
Could be a bad sender. Mine runs around 60psi when warm.
Old Jul 23, 2014 | 05:52 AM
92K1500's Avatar
92K1500
It's supposed to....
This is the reason 370's have oil temp instead of oil pressure.
Old Jul 23, 2014 | 05:57 AM
Carfreak70852
This is the reason 06+ cars have oil temp instead of oil pressure.
No they don't.
Source: I own an 06' and know the 07'/08's don't have oil temp.
Now, the 370z has an oil temp gauge instead of oil pressure if that is what you're talking about.
Old Jul 23, 2014 | 06:07 AM
92K1500's Avatar
92K1500
Originally Posted by Carfreak70852
No they don't.
That must be what I read. I thought that was one of the changes they made in 06 as well. It's too damn early in the day to be thinking....
Old Jul 23, 2014 | 07:06 AM
Carfreak70852
Haha I have been there. All good! I wish they did make that change, though. Would be way more beneficial to me. I had to add a gauge :/
Old Jul 23, 2014 | 07:33 AM
Ronin82's Avatar
Ronin82
-Bad sending unit
-going bad oil pump
-or your starting to burn more oil.
Old Jul 23, 2014 | 07:37 AM
Ronin82's Avatar
Ronin82
does your oil pressure noticeably drop when your making hard turns at a constant speed like on a freeway entry loop?
Old Jul 23, 2014 | 07:49 AM
92K1500's Avatar
92K1500
Ronin, he said the pressure goes up when he pushes the throttle. There is nothing wrong with his car...
Old Jul 23, 2014 | 07:52 AM
Ronin82's Avatar
Ronin82
loL.... yeah, I know
Old Oct 13, 2014 | 03:16 PM
Mikeybfromnd's Avatar
Mikeybfromnd
I'm having a similar issue and mine does drop in hard turns and braking.
Old Oct 13, 2014 | 10:37 PM
350Zdj's Avatar
350Zdj
At idle it the needle should be just around 12-15 psi.
Cruising should be around 60-80 depending on which gear or speed you're on.
If it's past 100 it means you're revving quite high. This is all normal. Unless it stays up there when you're idling or at lower RPMs. If this is what's happening, change the oil pressure sensor.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
sales@czp
Sep 23, 2019 03:30 PM
