Car pulling left in jerks?
Old Jul 31, 2014 | 11:51 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Default Car pulling left in jerks?
My car started pulling left a little about a week ago.
Yesterday after a ~350 drive, slowing down for a traffic jam, i noticed the front of the car shimmying left/right at around 5-10mph (not under load (braking/accel))
If i pull away from a stopped position, the car will roll, get to a certain point, and the steering wheel will pull left suddenly, moving it a few inches. If i continue rolling slowly, it will do it again, turning another couple of inches, perhaps at about the rotation of the wheels.
If i reverse the car, it will do the same thing, but to the right.
Getting up to speed the shimmying turns to a vibration, but not a metal on metal kind of vibration, it's not brake related, they don't bind or change the pull under braking. It's also pulling harder to the left than it was about a week ago.
Suspension is stock, about 88k miles.
Any ideas?
Thanks.
Old Jul 31, 2014 | 12:58 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Just had a thought, wheel bearing perhaps?
Old Jul 31, 2014 | 03:44 PM
zakmartin's Avatar
zakmartin
Something's freezing up or shifting. Could be bearings, brakes, suspension, steering rack, a loose bolt.... Have you lifted the front end and checked everything? Check for shimmying side to side and up and down on your wheels. Get under there and snap photos if you're unsure.
Old Jul 31, 2014 | 04:42 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Alright, never seen anything like it, but, it's the tyre...
It's one long bulge on the inside track of the tyre, about 8 inches long and a couple wide, it has just distorted the shape a little, but it certainly explains everything i've been feeling.
Going to order the new ones now
Old Jul 31, 2014 | 04:46 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Great, $378
Old Jul 31, 2014 | 08:31 PM
dkmura's Avatar
dkmura
General & DIY Moderator
$378 is a lot better than having that tire blow out at speed, causing you to lose control and ram the car next to you or a guardrail. Consider yourself blessed to have found it in time...
Old Jul 31, 2014 | 09:08 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Yes, yes it is.
I'm going to try and get some decent pics of this and post them. It's really quite interesting how it's gone, and you can see that it's been starting to go for a little while as the inside shoulder is more worn in the bulge area than the rest of the circumference.
Chris350z03
Oct 8, 2023 07:19 PM
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
RyansZ33
Sep 15, 2015 05:54 AM
