Help with modded clutch pedal
Old Aug 8, 2014 | 06:54 PM
omega007's Avatar
omega007
Default Help with modded clutch pedal
Hi, i bought a 350Z with the clutch pedal modded to be closer to the driver, but is was welded, so i need to buy the stock parts to return it to the stock position, here is a photo:
I asume i just have to buy a clutch pedal and a clutch slave cylinder, do i need something else?
Also could i just remove the end part that was welded with an extension on the clutch slave cylinder and leave the current clutch slave cylinder or it cannot be separated and the clutch slave cylinder has to be changed completely?
Old Aug 8, 2014 | 06:57 PM
travlee's Avatar
travlee
Master
i would get the rjm pedal assembly and a new slave cylinder and call it a day
Old Aug 8, 2014 | 07:01 PM
omega007's Avatar
omega007
thanks, but if i get a cheap used clutch slave cylinder can i just replace this part from inside the car without taking out the rest of it:
i dont want to change the entire part, just this piece, if is possible.
Old Aug 8, 2014 | 09:45 PM
dcains's Avatar
dcains
Master cylinder, not slave. And, +1 on the RJM adjustable pedal kit. Best mod on my '08.
Old Aug 9, 2014 | 01:13 PM
2000atlanticgt's Avatar
2000atlanticgt
Depends on how they modified the end of the master cylinder, it is an adjustable end piece that is threaded on and can be removed from the main rod of the master cylinder.
Old Aug 9, 2014 | 02:58 PM
omega007's Avatar
omega007
the end piece was bolted to the end of the regular end of the master cylinder
can this part be removed from inside the car on the stock master cylinder (since is where the extension was bolted, not threaded:
Old Aug 9, 2014 | 03:55 PM
NOLAGG's Avatar
NOLAGG
Yes it can
Old Aug 10, 2014 | 04:23 AM
dcains's Avatar
dcains
It can, and I'd be surprised if they did the welding of those pieces while they were under the dash. Get in there and have a close-up look for yourself. The hardest part will likely be getting the adjustment correct when you reinstall the part. Count the number of turns required to unthread it, so you can thread it on the same when you put it back.
Old Aug 10, 2014 | 09:42 AM
travlee's Avatar
travlee
Master
^that is why i suggested replacing the whole thing, but hey if OP wants to half *** it, by all means go right ahead
sherm
Apr 11, 2020 05:21 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
Tochigi_236
Sep 27, 2015 03:40 PM
