Vibrating Noise from the dash at around 45mph
Old Feb 5, 2004 | 06:23 AM
only1's Avatar
only1
Default Vibrating Noise from the dash at around 45mph
Anyone else getting a large vibrating noise from the passanger side dash? Im not sure what it is, but it goes in and out, dont know what is causing it.
Old Feb 10, 2004 | 11:42 AM
billg's Avatar
billg
Default Re: Vibrating Noise from the dash at around 45mph
Yes I have this rattle also and it drives me nuts. It kind of sounds like it is coming from behind my empty nav unit somewhere. It is at its worst at around 35-50 MPH when on semi-rough road (which are most roads in California). If anyone has an idea as to how to identify/fix this I would be thrilled.
Old Feb 11, 2004 | 10:40 AM
Sea Call's Avatar
Sea Call
Have the same problem - same location. Took it in to the dealer and they couldn't replicate / locate. It's still there. sounds like a marble rattling in the passenger side airbag housing.
Old Feb 11, 2004 | 10:52 AM
billg's Avatar
billg
Yeah, I had the dealer look for the rattle also and they said they couldn't reproce it. I don't think the really try. How long are rattles covered by the warranty?
Old Feb 11, 2004 | 12:59 PM
silverstoneTT's Avatar
silverstoneTT
i have a rattle, not near the passenger side but i havent bothered taking it in because i know they will just say they weren't able to reproduce it. my current fix for my problem is black felt pieces stuffed in the front area near windshield. itll do for now i suppose
Old Feb 11, 2004 | 01:52 PM
Ghostlight's Avatar
Ghostlight
Default Had the rattle fixed
I had the same problem with a rattle noise on the passengers side of the dash. it woulf happen when it was cold outside and when I was on pretty rough roads. Took it to the dealer three times and each time they said they could not find it or make it rattle to get an idea.
The last time I took it in I figured out that the service manager was marking it down as a rattle by the glove box (he was thinking the passeners side) well the service guys were looking behind the passengers seat where the real glove box is.
Long story short the found that the rattle was caused by the metal airbag frame hiting against the air vents in the dash so have your dealiers look into that.
The best way for them to find it is to leave it over night and have them test drive the car first thing in the morning when the car is cold.
good luck.
Old Feb 11, 2004 | 02:52 PM
only1's Avatar
only1
Mine isnt a cracking noise, but i weird vibrating noise. And its weird because it only happens at 45-50mph and smooth rodes will do it mostly.
I will have to ask the dealer about metal airbag frame thing.
Old Feb 12, 2004 | 09:56 AM
VandyZ's Avatar
VandyZ
The little round temp sensor near the glass on the passenger side rattles on mine. It seems to only do it in the cold and on certain roads. I know it it this because I have had several people push on it when it happens. I will fix it someday when I think about it.
Old Feb 12, 2004 | 10:11 AM
kamikaZ's Avatar
kamikaZ
3FIFTYZ
Yes, I have this rattle as well but I don't think I thought it was up over my gauges somewhere...not sure. Havn't bothered to ask the dealer I try my best to avoid dealing with them, never anything but aggrivation.
Old Feb 13, 2004 | 05:46 AM
only1's Avatar
only1
I will have to have my gf push on a few areas on the passanger side to see exactly where its coming from. Its like a "wide" vibrating noise that comes in for a few seconds and then goes away for a few seconds. Its really strange, cuz it doesnt sound like any of the other sounds from this car :-/
Old Feb 13, 2004 | 12:15 PM
Phatmitzu's Avatar
Phatmitzu
OMG...I cant believe it. Its the exactly same noise that I've been trying to find for the past 4 days...I thought it was only me...WTF?!
Old Feb 13, 2004 | 12:30 PM
BJF2K's Avatar
BJF2K
I think this thread should be moved to "To Nissan"
Old Feb 15, 2004 | 12:23 PM
edoan's Avatar
edoan
I am almost certain it's because it's winter right now. I/we never noticed this noise during the summer time because the ambient temperature was much higher, allowing the plastic to expand ever so slightly to fit together better. In the winter, of course, it's colder, causing the plastic to not expand to fill in any tiny gaps between panels. I'll wait till it gets warmer to see if the noise goes away before I let my dealer's mechanics tear my dash apart!
Old Feb 15, 2004 | 08:21 PM
only1's Avatar
only1
Well its so loud, and its constant, need something to be done.
Old Feb 16, 2004 | 04:05 PM
Spartan1510's Avatar
Spartan1510
I have this problem too. Crawled around under the dash yesterday but it was too cold to be out there too long.
IT'S DRIVING ME NUTS!
It sounds like its just behind / under the dash on the passenger side. I also think it's somewhere up high in the dash...basically impossible to get to without dismantling a portion of it.
I'm going to order the service manual to see if it has any good diagrams of the dash internals.
CAN ANYONE HELP US?! PLEEEEEASE!
...goin' nuts.
Old Feb 17, 2004 | 05:40 AM
billg's Avatar
billg
I think my rattle is originating from the temp sensor. I have tried to press down on it while driving and it appears to make the rattle go away. It seems to only rattle when the car is cold.
Old Feb 17, 2004 | 03:32 PM
Spartan1510
Where is the temp sensor????
Old Feb 17, 2004 | 05:20 PM
only1's Avatar
only1
I also get a low mumbled sound from the drivers dash, but if I hold the instrument panel, it goes away. Anyone have this one? Ill be going to the dealership on Saturday so I will keep everybody updated.
Old Feb 18, 2004 | 06:04 AM
billg's Avatar
billg
Its the little round thing near the windshield on the passenger side.
Old Feb 20, 2004 | 04:46 PM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
I have a rattle along the front of the entire dash, near the window. When I put my finger between the dash and window, it stops. I'm gonna go to Home Depot this weekend and get some small rubber or foam inserts to put there. Hopefully, that will do the trick.
Bat™
