0w-40 ok to use?
Old Sep 28, 2014 | 05:19 AM
cashmoney03's Avatar
cashmoney03
Synthetic doesn't affect the seals but the molecules are smaller and it can potentially leak through old seals.
Old Sep 28, 2014 | 05:29 AM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Wait...you guys use oil in your Z?
Old Sep 28, 2014 | 06:29 AM
dcains's Avatar
dcains
I use this in my Alfa's, but haven't tried it in the Z, yet:
Old Sep 28, 2014 | 06:46 AM
cashmoney03
I've always heard about the benefits of using olive oil in lieu of regular oil but haven't had the guts to try it.
Old Sep 28, 2014 | 09:00 PM
Bigsyke's Avatar
Bigsyke
Originally Posted by dcains
You obviously know much more about this topic than the engineers at Nissan. Nice to have you here on the forum.
Why don't you do a little research. We have an engine that beats up 30 weight oils. Add fuel dilution to the mix and you're below the buffer.
Do you stay at exactly 212*f/100c at the track? That is the viscosity the VQ was spec'd. I've seen temps around 260*f at the track. You would be way below the proper viscosity at that temp.
Originally Posted by cashmoney03
Bold statement to make with no data presented to support it. Especially given the volume of folks running 5w-30 in not just the z but other much higher performing engines.
People can run anything they want, but I hear of more high performance engines running 20w50 or 10w60 than 5w30. Why would you run an oil with a lower HTHS, worse cold starting properties, and less robust overall? I'd like to see you run M1 5w30 on a FI engine. I've done it, and I will never do it again. M1 0W40 is also a Group IV PAO oil. It is also less than $25 for 5qts at walmart.
Originally Posted by JONESBOY
Wow.
How long have you had your Z?
How many miles on it?
You have any data to support your statement?
I've had my current 350z for two years, and my Z32TT for 5 years. My 300zxtt has 200k on it, and has only seen 5w30 once. Otherwise it runs T6 or M1 0W40. Its my DD which sticks with 0w40 through MN winters. Oil pressure is still 65psi @ 3000rpms, and 20psi at 700rpms. I have also ran it dry for a whole lap on the track.
We have an engine with a timing chain. Have you felt the resonance at 2300-3000rpms? You need an oil with the highest HTHS, yet stays with-in the OE oil PSI specifications. 0w40 provides that.
Old Aug 9, 2018 | 04:12 PM
Granrex's Avatar
Granrex
Default Is it safe to use 0w-40?
Ey guys is safe to use 0w-40 instead of 5w-30 in my 07 350z?
Old Aug 9, 2018 | 04:40 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Sure. If you're in Watsonville, CA, there's no chance your oil will ever thin to 0w (even in Tahoe or anywhere up in the Sierra winters) nor get hot enough to raise visc to 40. Perfectly fine.
Old Aug 9, 2018 | 04:44 PM
Granrex's Avatar
Granrex
Am i going to feel any different with this change?
Old Aug 9, 2018 | 04:47 PM
dkmura's Avatar
dkmura
General & DIY Moderator
No- but depending on what brand and grade of oil you've been using, your VQ may thank you (by lasting a little longer).
Old Aug 9, 2018 | 04:52 PM
Granrex's Avatar
Granrex
Default 0w-40 brand and grade
So whats the best brand and grade for my 350z HR
im new here im glad i join so i want to take care of my z since
Old Aug 9, 2018 | 05:08 PM
dkmura's Avatar
dkmura
We're fortunate to have an excellent thread with plenty of factual data on what works well in the VQ35HR:
https://my350z.com/forum/vq35hr/3003...-analysis.html
For my money, I use Mobil 1 0-40W FS in both my race (HR) and street (DE) Zs. It's available at WalMart for about $26 (in 2018) for a five quart jug, and is also on sale at most car parts chains if you'd prefer.
Old Aug 10, 2018 | 12:38 PM
L0N3W0Lf's Avatar
L0N3W0Lf
Default Sup guys I have a Nissan 350z 2004 de.
What type of oil would you guys recommend in my z. I’ve been using mobile 1 5-30w
what’s the difference between 0–40w and the 5–30w
thanks guys
Old Aug 10, 2018 | 01:43 PM
MicVelo's Avatar
thanks guys
Highly oversimplified....
The numbers represent the relative viscosity (thickness, so to speak) of your oil, based on both ambient and engine internal operating temperatures. A multi-vis (multi-viscosity) oil "thins" to a lower rate for best flow when cold and "thickens" to the higher rate when hot - extremes in both ambient and op temp, say, a racing application).
First # is the thin weight (also called cold start weight) expressed as Xw (e.g. 5w or 5 Winter - the "w" does not stand for "weight" as is often confused). If it's cold out, oil will thin down to this minimum weight for cold start protection then...
Thicken up to as much as the second #, e.g. "40" for maximum protection at high running temperatures (obviously influenced by ambient temperature).
Nissan (and most mfgrs) recommend 5w-30 for most areas in North America (other areas, check your owner's manuals). Not much more protection is needed as even as there are extremes ranges of temps based on environmental factors (say negative degrees in Minnesota or Canada OR up to 110*F in Scottsdale, AZ as examples) do not require much more than this.
0w-40 then, by this logic, will thin down to 0 weight and thicken to 40 weight. But like I said, in most areas of the country, the additional swing range isn't necessary BUT it's not going to hurt.
jdmlove1
Oct 2, 2014 11:50 AM
dTor
Aug 12, 2007 01:24 PM
n8vz
Dec 12, 2003 07:07 PM
n8vz
Sep 1, 2003 08:26 AM
