Brake Squealing Ahhh!!!
Old Feb 6, 2004 | 12:28 PM
z4ken's Avatar
z4ken
Default Brake Squealing Ahhh!!!
Im having a brake squealing sound, shriek, like someone running their nails through a chalk board, coming from my Z. Ive previously had other brake noise, but its come and gone, this has been a little more persistent. I have 8000 miles on the car, and my commute has a lot of stop and go. Weathers been a little crappy but nothing too bad. Is this just normal wear and tear, or should I look into a new set of pads. The sound is freakin annoying. Any help is appreciated. Oh yeah the sound like in previous posts is from slow speed stops.
Old Feb 6, 2004 | 12:51 PM
orhanz33's Avatar
orhanz33
i have it to.... somebody suggested going to a deserted/queit area, and brake very hard from 60 mph. almost to a complete stop w/out stopping a few times... supposedly this is gonna create an even amount of wear on the rotors or something (break them in somehow)... i might try this when the weather gets warmer over here...i'm still debating wheather to do it or not since i never heard of anything like this before...
Old Feb 6, 2004 | 12:57 PM
HokieZ's Avatar
HokieZ
It's called bedding the brakes. You especially have to do it with new pads but if you've never done it, even with old ones, it's a good idea. Basically speed up to 40, then stop hard to 10, do that a few times, then from 60 to 10 4-5 times. By the time I was done, I could barely stop (lucky I didn't warp my rotors really) and have had no problems, even with the Hawk pads which supposedly squeak. Try it and I bet it works.
Old Feb 6, 2004 | 01:16 PM
z4ken's Avatar
z4ken
I'll try it after work. Im really close to a state park beach that is usually empty on the weekdays, especially with all this cold weather. Ill let you know the results. Thanks for the help.
Old Feb 7, 2004 | 02:46 PM
XBS's Avatar
XBS
Veteran
When you do this should the brakes and rotors already be warm i.e. u were driving the car for like 30 mins before or can it be done with them cold like u just started the car and started doing this? thanks. BTW i have hawk HPS pads and they squeak i always thought it was because when i changed them i didnt have time to resurface my rotors so i just sanded them by hand to get most of the old pad stuff off them thanks for you input
Old Feb 7, 2004 | 04:09 PM
rouxeny's Avatar
rouxeny
I've got 16000 or so miles and started getting a brake squeak a few thousand miles ago.
I think it has to do with the onset of winter.
Old Feb 7, 2004 | 06:19 PM
Michael-Dallas's Avatar
Michael-Dallas
Permatex Anti-Squeal Paste
For shimmed brake pads, apply the paste between the pad and the shim. For non-shimmed brake pads, you will need a different type of anti-squeal compound (I forget what it's called though).
If you're tracking your car, then I don't recommend using these products as they may carbonize due to extreme heat.
Michael.
Old Feb 7, 2004 | 09:33 PM
MY350Z.COM's Avatar
moved
07ZEKE
Aug 23, 2021 09:15 PM
samansharif
Sep 25, 2015 12:31 PM
