Instrumental Cluster issue
Old Jan 23, 2015 | 10:50 AM
ghostZ53's Avatar
ghostZ53
Default Instrumental Cluster issue
2003 Nissan 350Z Touring.
Got in my car this morning and started it up. The ABS, Brake, VDC, and slip lights were all on and stayed on. 3 hours later my Speedometer and RPM tacs quit working. The RPM tac will sometimes raise to about 2000 rpms and then the check engine light will start to flash. Then the RPM tac will fall back down and the check engine light will turn off. Hooked a code reader to it and was coming up with a bad Speed sensor. I looked online and it could require several things (new speed sensor/ bad sensors, cluster failure internally, fuse issue, etc. anyone have an idea of what could be causing this? Thanks.
Old Jan 23, 2015 | 01:10 PM
Kels88's Avatar
Kels88
First thing I would do is disconnect the battery overnight to see if it goes away in the morning. Some people say 15 mins or so, but it would have made me so worried/mad I would have had to sleep on it anyway
apex locator
Jul 23, 2021 02:27 AM
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
