passenger window switch issue
Old Feb 3, 2015 | 01:53 PM
350zMPH31b's Avatar
350zMPH31b
Default passenger window switch issue
I've come across what I believe to be a rather unique issue. First off let me describe what it's doing then how it happened. The pass side window on longer has the auto up feature auto down works fine and will still crack when opening the door but it will not shut back once closed. Using either driver or pass switch auto up does not work. Now for the how it happened I traded vehicles with a friend because I was needing to borrow a truck. While he had it he engaged the window lockout while the pass window was Down in an attempt to fix it he pulled the door panel off and used a power prob to bypass and force the window up. Since then no auto up with is a pain on rainy days with passengers because I gotta make them get out close the door then roll it back up so the car doesn't get soaked. I have tried another pass and driver switch from a G35 both did not fix it but the G35 was having window problems as is so not sure they were working switches I tried in the first place. Any help in any direction would be a God send at this point. Thanks in advance and I have already spent hrs searching for fixes using all data and direct hit and Google so please don't say have you googled iT.
Old Feb 3, 2015 | 02:17 PM
350zMPH31b's Avatar
350zMPH31b
I have also tried the reset Switch on the motor and the roll it down roll it up hold it for 10sec all to no success.
Old Feb 3, 2015 | 03:06 PM
92K1500's Avatar
92K1500
Are you pulling the screw out of the door jamb switch or holding the button in while you try to set the window travel?
If you don't push the button in or pull the screw out it wont work.
Old Feb 3, 2015 | 04:47 PM
350zMPH31b's Avatar
350zMPH31b
Yeah I have but thanks for the tip
Old Feb 6, 2015 | 12:37 PM
zakmartin's Avatar
zakmartin
If your friend didn't disconnect the switch or wiring to the motor before bypassing it with a power probe, there's a chance that he burned out the window control circuit on your BCM. Did your friend ask for permission before taking your car apart and going hog-wild with an unregulated power source? If not, I'd tell him he owes you for the repair bill.
Old Feb 6, 2015 | 12:48 PM
Syner's Avatar
Syner
When I first read this, I was thinking the same thing: It sounds like your friend owes you, OP.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
