royal purple oil confusion.
Old Mar 9, 2015 | 07:05 AM
turboed350z's Avatar
turboed350z
Default royal purple oil confusion.
Ok so recently, yesterday, i switched to royal purple. Ive always heard good things about them. And i figure why not.
Well me being the knowledge seeker that i am, i decided to research it. Me also being the idiot i am, only researched it AFTER the oil change.
Anyways i am hearing mix review both on this forum and other forums. Its pretty 50/50 as to whether royal purple is actually a good oil or not.
Chances are this thread will be 50/50 but i would just like fellow user's opinion on royal purple.
Old Mar 9, 2015 | 08:27 AM
Syner's Avatar
Syner
Castrol w/Syntec and Mobil 1 filter.
/thread.
Royal Purple is hyped up.
Old Mar 9, 2015 | 08:36 AM
KornerCarver's Avatar
KornerCarver
There is nothing wrong with Royal Purple. Your car will be fine.
Old Mar 9, 2015 | 08:51 AM
Syner's Avatar
Syner
https://my350z.com/forum/engine-and-...-and-info.html
Royal Purple is an average oil according to the UOA results. I personally choose oil that have better than average wear ratings.
Old Mar 9, 2015 | 08:59 AM
turboed350z
I too like above average and thats part of the reason i went with royal purple. I heard it was good. Then during my research i see things like "lubricant wears faster than normal oil" or that it "causes extra wear and tear in the engine"
I plan to go with castrol next oil change but im not sure if i should leave the royal purple in for now or switch it out.
Old Mar 9, 2015 | 09:04 AM
drvqz33's Avatar
drvqz33
+1
It really is hyped up. OP, check the oil analysis thread. There are oils that perform better in the VQs.
Old Mar 9, 2015 | 09:13 AM
Syner's Avatar
Syner
Leave it for now.
Old Mar 9, 2015 | 10:33 AM
bmccann101's Avatar
bmccann101
rotella, hks filters and lucas stabilizer ftmfw.
Ive lost an engine to a bearing before.
never again.
Old Mar 9, 2015 | 10:39 AM
turboed350z
never again.
Thats exactly what im afraid off. Ive heard that royal purple cause bearing failure. Not to mention turbo failure
Old Mar 9, 2015 | 11:33 AM
KornerCarver
If you are that concerned, I would change the oil for something that you are more comfortable with.
Old Mar 9, 2015 | 02:16 PM
WTFMike's Avatar
WTFMike
Rotella is what I run in my built motor turbo Z.
Old Mar 10, 2015 | 02:57 PM
oldschool350z's Avatar
oldschool350z
I've heard nothing but bad things about royal purple
Old Mar 26, 2015 | 11:08 AM
dlpannebakker's Avatar
dlpannebakker
Default Royal Purple
I have been using Royal Purple since 1993. The stuff that it it has done with my equipment is no less than amazing. The oil analysis's in my gasoline comes back better than the Amsoil as in my Dodge Diesel. I run it in everything I own, Ducati, Moto-Guzzi, Dodge W250 Cummins, we ran it in our 410 sprint car & our 368 sportsman.
Castrol is a substandard oil that has had issue dating back into the 70's. Valvoline is probably the next best oil on the market than comes Mobil1.
Use a good oil filter change it every 3-4 thousand miles with RP & you can get 20K out of the oil easy.
Old Mar 26, 2015 | 11:32 AM
taywan's Avatar
taywan
Rotella diesel oil in my built block now as well
Old Mar 26, 2015 | 12:47 PM
dlpannebakker
Rotella is a smart oil they use a fair amount of zinc in their oils which really helps against bearing failure & wear.
Take down an engine & look at the bearing wear when using another certain synthetic, they show a fairly worn main bearing & state, normal wear. If it's normal wear than why use the first in synthetics?
If you like you Retella stay with it. Nothing wrong with that.
Old Mar 27, 2015 | 04:15 AM
taywan's Avatar
taywan
I'm staying w it for the entire life of the block, if it doesn't blow up on me anyways.
Old Mar 27, 2015 | 10:55 AM
dlpannebakker
It shouldn't blow up, just keep the filters changed. Use a good filter! The only problem with Dino oils is they need to be changed out every 7500, filter every 3000-4000 miles. If in a diesel you can extend the oil changes since the diesel is a cleaner & not as harsh running engine over a gasoline engine.
Keep this in mind that about 80-90% or all filters made are made by one specialty company. Of course they do many different makes.
apex locator
Jul 23, 2021 02:27 AM
