Unsure what to do with bad catalytic converters
I just bought a 2008 350z and got a mechanic who is a Z freak to do a quick check over it (Haven't yet taken it to my main mechanic to REALLY get it checked out), and he said there are/is bad cat converter(s). He said there could be loose materials (There is a dull rattling when idle) working their way into the engine and causing some damage, or something along those lines. BUT when I asked my main and trusted mechanic he said that they shouldn't cause any damage and to just run with it.
Is this a serious problem that needs to be fixed, and if so what should I do? I need something relatively cheap (around $1,000 range including installation), but I also don't want to get the wrong cats and end up with a terrible ricer whine. Should I get HFCs? Are the really cheap universal cats any good? What about resonators?
I'm worried about there being an annoying loudness when I'm driving around the city.
Changing the cats alone won't alter the sound of the car too much, if you're running a stock exhaust then you still have a resonator in the mid pipe and a muffler, there are ways of testing the cats, with a gauge that takes the place of one of the 02 sensors, the gauge will show how much pressure is building up in the cats, if the cats are clogged and the exhaust isn't able to flow out of the engine the car would be running very poorly and would like throw codes, high flow cats would be a good option regardless, I don't buy the mechanic being able to hear a rattle in the cats at idle, given the amount of things on the car that can rattle, I know the most notable thing I can hear at idle with the car in neutral is the flywheel
Actually, it wouldn't matter either way I got like 103k on it.
Don't cheap out on exhaust parts, unless you're getting test pipes. Test pipes are test pipes are test pipes. But I would still go with a reputable brand. I personally have had the OEM cats replaced on my 08 and I would sell you mine so I can get aftermarket cat replacements
The cheapest I would go on my car would be Megan. check out t he 370z. c o m or my g37 dot com for some OEM replacements from people parting their cars.
I would expect you to run lean. If you test your arf and its fine then sweet. Save the 700 bucks and buy more parts. However, a tune will ensure the engine is running properly AND add some more power.
