vibration at 80 mph, comes and goes
Old Sep 26, 2015 | 06:46 PM
  #101
black38's Avatar
black38
yeah reading up on them in the last 30 mins or so i have heard the same.
I don't want to go solid though.
I daily my car and have yet to take it to a track (not sure if i ever plan to)
Old Sep 26, 2015 | 08:03 PM
  #102
Vigman's Avatar
Vigman
So it's hard to see in the pix is the bushing rotted or is the bolt missing?
How are the 2 bushings that hold the input of the diff to the subframe??
Old Sep 27, 2015 | 05:24 AM
  #103
travlee's Avatar
travlee
Master
it sits back in there, and i think it dry rots and then oozes the goo out. i have never personally seen the ears blow out, just the subframe one
Old Sep 27, 2015 | 08:33 AM
  #104
Italianjoe1's Avatar
Italianjoe1
Originally Posted by black38
So i think i found the problem
time to order some whiteline bushings unless someone like a different brand better
When mine failed and I swapped to the whitelines, I still had that highway vibration that came and went above 80. Never did figure it out.
Old Sep 27, 2015 | 08:44 AM
  #105
black38's Avatar
black38
its in there.
It doesn't matter, all of them will be changed out.
I think im going to swap the trans bushing as well
That sucks. This almost inspires no confidence to swap out the bushing...
Old Sep 27, 2015 | 08:49 AM
  #106
Italianjoe1
I don't remember when the vibration started honestly. I've changed wheels/tires after and no difference. I'm assuming it's driveline, as Nissan put a trans in the car once under warranty, and I took it out for a clutch install later on down the road. So i'm guessing after one of those jobs the driveshaft got clocked wrong or something, or maybe it didn't like the aftermarket flywheel. It really only shows up past 80mph though so it's hard to troubleshoot.
Old Sep 27, 2015 | 08:55 AM
  #107
black38's Avatar
black38
well as in a previous post, at 30-35 i can feel a physical bouncing and also a vibration before 80. So swap out bushings, make sure the car doesnt rattle around, then trade it in.
Old Sep 27, 2015 | 09:06 AM
  #108
Italianjoe1
Lol I just didn't worry about it, I don't spend a lot of time cruising above 80, and when I was racing a little vibration through the shifter wasn't really gonna get my attention. The low speed bouncing may be from the failed diff bushing, that I can't say. I started to notice increased wheel-hop on hard launches, found the bushing leaking, replaced it.
Old Sep 27, 2015 | 03:42 PM
  #109
black38's Avatar
black38
what bushing did you replace it with?
Old Sep 29, 2015 | 12:46 PM
  #110
difranchise's Avatar
difranchise
This is interesting.
My car only has 58k as an 06, but I may consider changing the rear diff bushings cause of the symptoms.
To reiterate. at and above 75mph (comes and goes) I get a vibration that almost makes the car feel less attached to the road. Disconnected so to speak.
It is frustrating and after storage this winter I think it will be first on the list. Keep us updated guys....
Old Sep 29, 2015 | 04:30 PM
  #111
Italianjoe1
I did the whiteline poly kit, all three points, the yellow bushings.
Old Oct 2, 2015 | 05:53 PM
  #112
black38's Avatar
black38
whiteline kit bought, should get it back tomorrow
Old Oct 4, 2015 | 03:52 PM
  #113
black38's Avatar
black38
$350, still have the shake. time to burn it
Old Oct 4, 2015 | 04:06 PM
  #114
travlee's Avatar
travlee
Master
you feel it in the steering wheel or in your butt?
Old Oct 5, 2015 | 06:49 PM
  #115
black38's Avatar
black38
in my butt mostly, slightly in the shifter
Old Oct 6, 2015 | 03:09 AM
  #116
travlee's Avatar
travlee
Master
might be trans mounts... and you double checked nothing is wrapped around the drift shaft right
Old Oct 6, 2015 | 06:55 PM
  #117
black38's Avatar
black38
i did double check that there was nothing wrapped around it.
The mechanic that did my diff bushing. He said he did all he could to see if it was bad (read:shook the ish out if) and there was no play.
Old Oct 15, 2015 | 08:32 PM
  #118
black38's Avatar
black38
found someone willing to borrow their wheels for a few minutes. updates after the weekend
Old Oct 16, 2015 | 03:11 AM
  #119
travlee's Avatar
travlee
Master
has this led you to drinking already?
Old Oct 16, 2015 | 05:24 AM
  #120
JCat's Avatar
JCat
I had this problem on a Mustang. It turned out to be a bent or unbalanced drive shaft.
I replaced the drive shaft and u-joints and the problem disappeared.
While towing, was it on a dolly? Rear wheels on the ground? Did you ever remove the drive shaft in this car ?
