help figure out if it's slave cylinder.
Old Aug 19, 2015 | 11:45 AM
jzk91's Avatar
jzk91
Default help figure out if it's slave cylinder.
Hi, i have little problem, and i think it might be slave and master cylinder that might cause the problem on my car with little reaserch on forum. But i am not too sure about it and want to see if others had similar experiance like me. Car was fine last night I drove it, but today when i stepped on clutch, it got stuck and only comes out half way. And the gear also won't go in. It's 06 and I replaced clutch 2 month ago with full kit. Its confusing because it was driving just perfect yesterday and happened so sudden.
Old Aug 19, 2015 | 11:48 AM
travlee's Avatar
travlee
Master
you could try just changing the fluid, but if it were me... i would just change the master and the slave.
Old Aug 19, 2015 | 11:53 AM
travlee's Avatar
travlee
Master
here are some parts, depends on how much you want to spend
http://www.zspeedperformance.com/
Old Aug 19, 2015 | 11:58 AM
jzk91's Avatar
jzk91
Thank you for your help. So are my problems caused by bad slave and master cylinder? I know you can't really say but are the the symptoms of bad slave and master cylinder like mine??
Old Aug 19, 2015 | 12:05 PM
Heel Til I Die's Avatar
Heel Til I Die
I had the same issue with my clutch pedal only popping back up about halfway. Went with the Wilwood master cylinder from zspeed and all has been good since then. If you do end up replacing the master, you may as well do the slave at the same time to avoid any other problems in the future.
Old Aug 19, 2015 | 12:17 PM
jzk91's Avatar
jzk91
I guess I am ordering them both. Thank you for them help.
Old Aug 19, 2015 | 12:18 PM
travlee's Avatar
travlee
Master
it really sounds like it to me.... but like Heel said, replace them together
Old Aug 20, 2015 | 09:41 AM
Heel Til I Die
If you do end up going with the Wilwood master (which I would highly recommend), you'll need to reuse the OEM reservoir and some of the OEM hose that connects the two. Personally, I upgraded to a Wilwood reservoir so I could use my Motive power bleeder and not have to hassle with the Z's unconventional bleeding procedure found in the FSM.
Wilwood now sells a kit which has everything you need for the reservoir swap found in this excellent write-up: https://my350z.com/forum/engine-driv...voir-swap.html
DIY for master replacement: https://my350z.com/forum/engine-driv...-cylinder.html
Link to reservoir kit from Wilwood (product no.: 260-11098): http://www.wilwood.com/MasterCylinde...emno=260-11098
Good luck!
Old Aug 20, 2015 | 01:43 PM
jzk91's Avatar
jzk91
Thank you for the information. That diy is helping me big time
lapham3
Oct 7, 2022 03:15 PM
07ZEKE
Aug 23, 2021 09:15 PM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
