Noise coming from rear when abruptly accelerating in high gear
Old Oct 22, 2015 | 07:10 PM
ukraini9mofo's Avatar
ukraini9mofo
Default Noise coming from rear when abruptly accelerating in high gear
Hey guys
So today when I was driving and going about 60 in 6th (also noticed in 5th) and I punch gas pedal sharply and feel car jerk forward (but obviously not speeding up quickly since its in 6th gear) there is this thump coming from rear (sounds like from diff). If I don't punch gas pedal abruptly, just push it down it doesn't do it. Also doesn't do it under shifts or hard acceleration in 1st 2nd or 3rd. Any ideas?
Its 2008 80k
Old Oct 22, 2015 | 07:19 PM
ukraini9mofo
Also its not the clicking sound that is a common issue its more of a loud thump as the drivetrain is twisting from the load of being in low RPM and high gear. I know its not a good idea to be doing this (makes no sense to floor it abruptly in 6th going 60 mph) and I never did it before just happened to today and noticed it .
Old Oct 22, 2015 | 08:17 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Have you jacked up the car (supported with jack stands) and checked the driveline? It could be worn diff bearings or loose driveshaft fasteners. Or a thousand other things a physical check will turn up. Let us know what YOU find...
Old Oct 22, 2015 | 08:41 PM
ukraini9mofo
Will get it on a lift this weekend hopefully, but I have been reading the rear bushing thread and thinking of getting the rear diff brace, since I'm only getting that sound in this scenario alleviating some pressure off the diff mounts might help ?
Old Oct 22, 2015 | 08:45 PM
dkmura's Avatar
dkmura
If the diff bearing is worn, a brace will only make the clunking worse. Do the assessment first, before deciding what needs to be replaced.
Old Oct 22, 2015 | 09:52 PM
ukraini9mofo
Whats the best way to see if diff bearing is worn (obviously if I'm not seeing any leaks)
Thanks
Old Oct 23, 2015 | 09:32 AM
dkmura's Avatar
dkmura
You won't see any leaks, either. The side bushings are rubber and you may need to pull one of the bolts to inspect it. The rear bushing should be visible from the rear subframe and you may be able to move it slightly with your arms on a lift. Check to see if any of the driveline bolts are loose while you're in there,
Old Oct 23, 2015 | 06:22 PM
ukraini9mofo
All good!
CS350Z86
May 27, 2010 01:16 PM
Sylvan Lake V35
Jul 21, 2008 09:38 PM
deprived...Not
Mar 23, 2007 01:46 PM
Swiffer
Dec 3, 2006 07:23 PM
Kabs
Aug 19, 2006 04:37 PM
