cam positioner senser
I installed a cam positioner in my car because after being checked with computer.Now it will jerk violently and it has no power but will stay running. Any answers ?
in other words... what else did you do? my guess is nothing.... instead of doing some real troubleshooting you came here
thanks I will try that when my sons friend can look at it again. he is the one with the diagnostic computer. I live out in the country, so I can`t drive it to town. I don`t pretend to very knowledgeable with cars. Thank you for your courteous reply unlike the other response .
Hi Wally... At about 85k I replaced one cam position sensor on my 2003 350z when throwing this code.
I was OK for a couple weeks and then experienced the problem you report (faltering power). The new problem code advised replacing the other camshaft position sensor. I did that and all was fine for 6 months when I started having power problem and the code was a crankshaft sensor. This time I replaced both sides, and that fixed the problem.
My most recent SES light was prompted by a faulty oxygen sensor code. I replaced that and all was well.
Yesterday the SES light went on again. I’m off to the shop tomorrow to discover the code and what sensor needs replacing now.
--Spike
--Spike
I tried resetting the ECU the manual way using the ignition key & the gas pedal. It worked, clearing the ECU. But about 15 miles into the drive,it started with stalling & loss of power. It also went to the max on heat gauge. I haven't been able to drive it anywhere to get it checked. Anyone have any ideas ? maybe the other cam positioner sensor is bad also?
koren
South East Marketplace
Jun 6, 2016 09:07 PM
George's350z
Oct 22, 2015 03:19 AM
