Plug failed at 20k miles
Old Nov 30, 2015 | 06:13 PM
gossf's Avatar
gossf
Default Plug failed at 20k miles
So I got an intermittent misfire in cylinder 5 while idling, and I suspected the coil pack, but after switching the coil-pack with another one without the misfire moving, I suspected a plug, so I changed it out, and presto, misfire gone. I'm wondering why this plug failed at 20k miles, I used the OE denso iridium plugs. I should mention that I did test pipes and and exhaust and ran like that for about 6 months (I think It ran with the AFR slightly off) without a tune, then got it tuned all on these plugs, maybe that stressed the plug to premature failure, although none of the other plugs have shown signs of failure yet, and the plug showed normal wear, looked healthy. Did I just get a bum plug? Or should I suspect some other problem condition that caused this.
Old Nov 30, 2015 | 06:53 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Densos and NGKs generally have very good QC. If the plug looks good, you might try swapping it with another one and seeing what happens.
Old Nov 30, 2015 | 07:53 PM
gossf's Avatar
gossf
I did replace the plug with the one I bought to test out the coils and now I don't get any misses, so I do believe that was the problem (unless there was some other issue that happened to rectify it's self). Just left trying to figure out why the plug failed so prematurely and wondering if there is another issue at hand I should investigate.
Old Dec 1, 2015 | 03:28 AM
jhc's Avatar
jhc
General & Tech Moderator
When you say "failed" you are referring to misfire only, or fouled and worn electrode on visual inspection?
Old Dec 1, 2015 | 05:43 AM
gossf's Avatar
gossf
It only had an intermittent misfire, the plug looked perfectly healthy.
Old Dec 1, 2015 | 03:14 PM
zakmartin's Avatar
zakmartin
Call Denso and tell them you have a crap plug and want it replaced under warranty.
PintofBrew
Dec 2, 2015 11:13 PM
Ryan Lemons
Dec 1, 2015 03:44 PM
johnww99
Nov 30, 2015 02:18 PM
Ryan Lemons
Nov 30, 2015 03:55 AM
dpierce33967
Tuning
Nov 25, 2015 03:17 PM
