Trunk open question?
Old Dec 2, 2015 | 07:36 AM
Tripdaddy's Avatar
Tripdaddy
Default Trunk open question?
I just purchased a 2004 touring convertible. As I am working through learning the nuances of it, I noticed the trunk does not "pop" open. Yes I know how to open it with the key fob or the button above the license plate. I just have to stick my fingers in the crack and lift it. Once open, it stays as long as I am over 50% open. I'm assuming it's the trunk struts and those need to be replaced. Am I on the right track or is this a design issue?
thanks
Old Dec 2, 2015 | 08:08 AM
turboed350z's Avatar
turboed350z
Worn springs. Could replace or do the nickle trick
Old Dec 2, 2015 | 08:23 AM
travlee's Avatar
travlee
Master
https://www.courtesyparts.com/nissan...ft-gate-spring
Old Dec 2, 2015 | 09:10 AM
Tripdaddy's Avatar
Tripdaddy
OK I see the springs now on the trunk lid by the latch. I took them out and was able to easily squeeze them with my thumb. I would assume since there was little resistance they are worn and need to be replaced.
Old Dec 2, 2015 | 09:28 AM
travlee's Avatar
travlee
Master
you are correct, the new ones you wont be able to compress at all
Old Dec 2, 2015 | 09:38 AM
Tripdaddy's Avatar
Tripdaddy
Thank you kind sirs. Travlee thanks for the link. that seems to be the best price i can find. And it's from an actual dealer. I called my local dealer and he said that's a good price and he could not match it.
Old Dec 2, 2015 | 09:40 AM
travlee's Avatar
travlee
Master
you will rarely find a place cheaper than courtesy, loved that place when i still had my nissan.... 10 min up the road from me
Old Dec 2, 2015 | 10:35 AM
verdict.'s Avatar
verdict.
+1 on Courtesy. Pretty simple fix.
Old Dec 2, 2015 | 03:22 PM
zakmartin's Avatar
zakmartin
As mentioned by turboed350z, just add a couple nickles inside the rubber spring casing. It'll shim the springs enough to give them the energy they need to pop the hatch open.
Old Dec 2, 2015 | 05:33 PM
35th4me's Avatar
35th4me
I'm there a lot!
Old Dec 3, 2015 | 10:34 AM
DRELOC's Avatar
DRELOC
Is this the same concept with non convertible Z just replace the springs? Mine has the same issue unless I press the button by license plate & lift the hatch at the same time it won't open
Old Dec 3, 2015 | 10:36 AM
travlee's Avatar
travlee
Master
should be,
EnjukuRacing
Body Interior
Feb 1, 2016 08:08 AM
prfectz
Brakes
Dec 13, 2015 06:41 PM
35reilly
Dec 2, 2015 10:01 AM
UZ_
Dec 2, 2015 05:17 AM
Detailed Image
Cleaning & Detailing
Dec 1, 2015 03:11 AM
