Silly question...
Old Jan 1, 2016 | 03:03 PM
chari's Avatar
chari
Default Silly question...
Happy New Year everyone!!
Doing laundry today but at the same time taking a peek under the Z's hood to make sure engine oil level is good and the other fluids are as well. The clutch fluid level is at minimum right now. Is it ok to fill it up with dot3 brake fluid? I know it says to do that on the regular brake thing but I just wanted to be sure before I fill it up.
Old Jan 1, 2016 | 03:15 PM
Monsta's Avatar
Monsta
I believe the owners manual says to use DOT 3. Read it and fill with what it calls for.
What is the "regular brake thing"?
Old Jan 1, 2016 | 03:17 PM
terrasmak's Avatar
Dot 3 is the proper Spec, but I only use Dot 4 in my car. Dot 4 takes a little more heat that can happen if you play with your car a bit.
Old Jan 1, 2016 | 04:43 PM
venture210's Avatar
venture210
+1 to dot 4. Either one will be fine though OP
Old Jan 1, 2016 | 06:17 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Yay its Chari...
I believe dot 3 is the one to use. Some people change to 4 but if your topping it off it shouldn't matter much...
Happy New Year, and hope you had a wonderful holiday season.
Old Jan 6, 2016 | 10:27 PM
chari's Avatar
chari
Thanks
Was just asking cuz on the brake fluid filler cap it mentions to fill with dot 3 but doesn't mention that on the clutch filler cap and I just wanted to be sure dot 3 was ok to top the clutch compartment off with.
Old Jan 7, 2016 | 05:24 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Both DOT 3 and 4 are compatible, so topping off with either would be OK. You should also consider that brake fluid does age, and needs replacing every 4-5 years. If you've never had this done (or bled either the clutch or brake master), you might consider upgrading your brake fluid to a high-quality DOT 4 fluid with a high boiling point (like ATE Gold 200) when you replace most of the fluid in the system.
Old Jan 7, 2016 | 10:02 AM
zakmartin's Avatar
zakmartin
Don't use Prestone Dot 3 Brake Fluid. It causes more problems than it solves. Stick with Valvoline Synthetic DOT 3 & 4 Brake Fluid. It will improve your clutch's performance, especially if you do a full clutch fluid bleed with it on an '07-'09.
350z-900whp
Feb 12, 2016 03:05 AM
shyun1250
Jan 5, 2016 10:45 AM
Smokey Bear
Jan 1, 2016 07:04 PM
Detailed Image
Cleaning & Detailing
Dec 31, 2015 04:58 AM
