Extremely low oil pressure 2003 Enthusiast 151k
Ah ok, fair enough. We have a lift too, but was just curious.
Thank you sir! Appreciate that. It seems to be a fairly straight forward job. Any special tools required? Seems like chain vice grip and something able to loosen the crank bolt are the only things out of the ordinary to do the job, from what I've been reading.
I would recommend getting some plastic razor blades to scrape the rtv they worked well for me without any need to chemical removers. Also if you use an RTV cutter like this they plastic razor blades will help keep the cover separated while you are taping it around the sealing surface. The caliper compressor looks much easier.
http://www.ebay.com/itm/RTV-Gasket-C...SoO5h8I4_iLPyg
I would also recommend taking the bumper and rad support off it makes working much easier but does add time to the repair. A/C condenser can get set to the side as the fittings rotate.
Just carefully cut the gasket around the cover, insert tool between the two casting tabs and slowly pop it off. Works like a charm
Just curious if anyone has tried to live with this issue? I hate the oil pressure light but if it isn't going to nuke my engine I'm hesitant to shell out the $1200+ it is going to cost me to fix this gasket. Thoughts?
While you are lucky the pressure is going to build with engine RPM unlike a blocked passage or dead pump you still have oil pressure low enough to damage bearings. This is assuming the issue is the gaskets.
Your best course of action assuming you have verified the oil pressure is low, is to park the car and save the money to get it fixed.
Well if you have verified its actually the pressure getting that low then yea you can kill the motor.
Thanks for the reply. Car has all the symptoms of a blown gallery gasket, pressure seems fine for first 10 or 15 mins of driving then once it is up to full temp I start getting the oil pressure light at idle. No codes though and doesn't seem to be knocking. If I keep the AC on it seems to keep the idle high enough to not trigger the light. It pains me to shell out the cash for fixing such a dumb part, Nissan really sucks sometimes.
I had the same thing going on, hooked up my mechanical gauge just to confirm and it was super low. The job isn't terribly difficult but definitely time consuming. Good Luck.
Once I replaced mine pressure was above spec. - I ordered the set from ConceptZPerformance to prevent it from ever happening again.
After the fix my pressures are ~27psi at idle and ~60psi at 2K rpm with the oil temp a 200-210F.
