Speedometer not working and convertible problems
Old Mar 22, 2016 | 03:18 PM
Richyysg's Avatar
Richyysg
Default Speedometer not working and convertible problems
Got a new to me but used 05 350z it is convertible and 2 big problems for now,
1. All my gauges light up as they should but none of the gauges move, my gas reads E, both speedometers don't move(even at start up), the only gauges that do move are my oil and battery gauge, otherwise everything sits still but lights up my brake light is always on as well.
2. The convertible module is fryed so i have to get a new one but any chance that this might be the issue of my speedo not working?
Old Mar 22, 2016 | 07:07 PM
icer5160's Avatar
icer5160
Could be an electrical short, not sure. I've never heard of anyone with a 350Z have a gauge cluster suddenly stop working in the manner you described. You can try double checking the electrical plug connection to the cluster. It's pretty easy to access once you remove a few panels. Was this convertible a victim of water damage? Check all the fuses.
-Icer
Old Mar 22, 2016 | 07:18 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Have you looked at the 350Z manual? Might want to find those PDF's and see if there's anything about the electrical system in there.
It's section IP in the manual.
Old Mar 22, 2016 | 08:25 PM
Richyysg's Avatar
Richyysg
Fixed it, finally found a helpful thread and found out it was a blown fuse, gonna order a new convertible module and my z should be all good, thanks for the suggestions!
Old Mar 23, 2016 | 03:07 AM
Timmy Tran's Avatar
Timmy Tran
Nooooo just refurbish your convertible top motor. 10$ to fix it compared to 700$
Old Mar 23, 2016 | 06:25 AM
Richyysg's Avatar
Richyysg
I would but idk where i could take it to get it fixed, the electronic board has pieces that are fryed.
Old Mar 23, 2016 | 11:20 AM
CNunes_95's Avatar
CNunes_95
Inspect the speed wire that plugs into the ECU. I don't know what color the wire is, but mine was purple and white. When I was installing my subs, i crushed the wire while trying to put my radio back in. Afterwards, my speedometer and odometer was not working. I inspected the wire and saw the crushed point in the wire. I cut it out and re-spliced the wire and was all good again
Old Mar 25, 2016 | 04:08 PM
Timmy Tran's Avatar
Timmy Tran
This convertible top "module." Are you referring to the motor underneath the rear glass window? Or something else? Because if it's the motor underneath the rear glass window, there's an excellent guide on this forum that shows you how to refurbish it; one that I followed and now my top works like new.
Old Mar 26, 2016 | 07:02 AM
Richyysg's Avatar
Richyysg
No its the module in the storage for the soft top
Suspension
Mar 29, 2016 06:52 PM
mreed772
Mar 24, 2016 07:50 AM
str8upspeed
Intake
Mar 24, 2016 07:47 AM
Williams_USN
Mar 21, 2016 08:22 AM
