350z is slow
Old Jun 8, 2016 | 08:36 AM
dan_man's Avatar
dan_man
Default 350z is slow
Hey guys, I'm new to the z ownership as I just picked up a used 03 touring about a month ago. I am having an issue I can't seem to solve and I need some help. My car is slow. It feels like it has about 200hp. I know 'feels' is subjective, but the best 0-60 Ican do is 6.8 and the best quarter mile is 15.9. I drove my friends Z and I can achieve stock 0-60 and quarter mile times in his car(1yr newer). My issue is, I don't know whats wrong with the car. Repacled the knock sensor and sub harness which helped. Had code for it being bad. Also had a misfire in cylinder 4 and 2. All new plugs, and two replaced coil packs solved the problem. I have no more engine codes, no stalling, no bad idle, no hard starts, haven't noticed any vaccum leaks, everything appears to be working, but the power just isn't there. I'm not interested in racing, I just want stock performace back. What could be causing my issue? Car has 120k miles.
Old Jun 8, 2016 | 09:30 AM
iideadeyeii's Avatar
iideadeyeii
Do a compression test and respond once you have the numbers
Old Jun 8, 2016 | 10:38 AM
bboypuertoroc's Avatar
bboypuertoroc
This.
Old Jun 8, 2016 | 10:47 AM
travlee's Avatar
travlee
Master
let me gaze into my internet mechanic crystal ball......
Old Jun 8, 2016 | 11:00 AM
bboypuertoroc
let me gaze
me gaze
meat gaze
me gays
Sounds about right.
Old Jun 8, 2016 | 11:07 AM
travlee's Avatar
travlee
Master
Old Jun 8, 2016 | 01:03 PM
turboed350z's Avatar
turboed350z
Originally Posted by bboypuertoroc
Sounds about right.
Bboy is onto somthing here.... the signs are all adding up now...
Old Jun 13, 2016 | 09:21 PM
dan_man's Avatar
dan_man
Right, sorry it took so long to reply. I work nights.
Compression as follows- #2-152 #4-154 #6-152 #1-180 #3-160 #5-160
Could it possibly be a bad crank sensor, or cam sensor? I would expect those to throw a code though... but maybe not
Old Jun 13, 2016 | 09:28 PM
dan_man's Avatar
dan_man
Cleaned the pvc, coolant is running at 91 degrees so temp sensor is working, cleaned maf, tried resetting the ecu. only other thing I can think of is the throttle position sensor..?
tail lights are stock.
Old Jun 14, 2016 | 05:26 AM
bboypuertoroc
That 180psi on cylinder 1 doesn't sound good. Limit between cylinders on a VQ35 is 14 PSI. The rest seem fine for the age of the engine.
Old Jun 14, 2016 | 05:27 AM
bboypuertoroc
Thank Cthulhu
Old Jun 14, 2016 | 06:12 AM
dan_man's Avatar
dan_man
Idk what would cause that cylinder to be a higher compression. I wouldn't think that could be robbing power from the engine though?
Old Jun 14, 2016 | 06:18 AM
bboypuertoroc
How many times did you run the compression test? How long did you crank each cylinder?
Old Jun 14, 2016 | 06:21 AM
dan_man's Avatar
dan_man
Since my compression is pretty much normal for the age, any other suggestions? Things to check? I'm willing to put in the work.
Old Jun 14, 2016 | 06:23 AM
dan_man's Avatar
dan_man
Cranked each cylinder for about 4 secs. Twice
Old Jun 14, 2016 | 06:47 AM
bboypuertoroc
Compression seems fine other than the one cylinder. Maybe carbon build up.
Old Jun 14, 2016 | 07:15 AM
iideadeyeii
Standard compression is 185psi max 14psi between cylinders
So, simple math
185*6=1110
152+154+152+180+160+160=958
958/1110=.863*287=247.68hp
You're losing approx 40hp based on your compression test.
Old Jun 14, 2016 | 09:14 AM
dan_man's Avatar
dan_man
So, simple math
185*6=1110
So to regain lost power I need a engine rebuild? I thought the minimum tolerance was 142psi.
jason08z33
Apr 12, 2016 06:04 PM
CK_32
Apr 1, 2016 08:06 AM
ashram
Mar 30, 2016 10:44 PM
Sak350
Mar 27, 2016 08:41 AM
