rear passenger lug nuts keep coming loose
Either I found out I have an enemy, or something fishy is going on with my 03 z.
Ive been doing alot of drifting and drag racing along with the canyon runs. Never had an issue with my lugs coming loose.
Naturally my brain says "lug nuts dont loosen themselves". But something is telling me there is other factors at play.
I noticed when I heard a "ching ching ching ching" noise coming from the rear. Scope it out and 1 lug is missing the other 4 are barely on. Easily turned by hand. This happened after drifting a couple circle's.
I torqued the remaining 4 down to 93ftlb. I had to do a 3 hour drive (1.5 there 1.5 back) Drove there. All Good. Get off the freeway on the way back.... Ching ching ching ching. WTF.
I never had this issue the past 2 years of owning this car and now it wont stop. Please any insight is appreciated.
The other factors at play here are not mentioned in your post. Are you using OEM or aftermarket wheels? Also, have you changed lug nuts recently, or has something changed about the lug seats themselves ?
Aftermarket xxr 20 inch rims. I havent changed the lugnuts ever. Im assuming they are what came with the rims as every lug is keyed. I did do a rear brake job not too long ago but have put on many miles since (over 1k).
Do some research on the lug seats for your XXR wheels. If they do not match the type of lug nut you are using, they will never stay tight.
