Loss of Power, wet spark plugs with fuel P0300
Old 09-12-2016, 02:57 AM
ATIX
ATIX's Avatar
Question Loss of Power, wet spark plugs with fuel P0300
Hi everyone! after carefully reading everything I can about the problem & regarding a P0300, I cannot find concluding information on a proper solution.
So Initially I got p0300 and p0301, I swapped the coils 1 & 2 and the P0301 went away, so I'm left with P0300. Car engine lacks power on acceleration (All spark plugs smell like gas) 153 k miles 6 speed manual
-The car starts fine, P0300 code indicates misfire. So I checked:
1. Cleaned the MAF sensor
2. Replaced spark plugs
3. PCV Valve replaced
4. I don't see or hear any leaks (Might have to redo this)
5. Replaced cat with straight pipes (same power no improvement)
6. Checked All coils with multimeter @ 200k OhmsΩ and most are at 123.4 Ohms/1.5 Ohms Except one I only get the reading of 1 Ohm (default value, maybe it's bad)
7. Checked injectors resistance and are all same @ 17 Ohms
8. Checked engine compression @ 190 psi on all
(Should I order a coil Pack?) I read in previous post that some guy mentioned visiting 2 repair shops regarding coils and they usually order a lot of coils for the Z and G35 since they go bad.
-I'm left thinking about testing or replacing the fuel pressure regulator or the Fuel pump due to loss of power according to this post:
https://my350z.com/forum/engine-and-...ml#post8642752
Any help is greatly appreciated please.
(Also here is my extensive troubleshooting log from the previous work I've done on the car:
http://mechanics.stackexchange.com/q...nks-wont-start )
Old 09-12-2016, 05:31 AM
MartinZ
MartinZ's Avatar
Check the coil with 1 ohm again - could be a bad contact - but if that is the correct reading it's 30% different to the rest which would be a concern
Double check for vacuum leaks - spray degreaser around - if you see bubbles you've found the leak
Check fuel pressure
Run 1 tank with injector cleaner
Bad fuel?
ATIX (09-12-2016)
Old 09-12-2016, 02:06 PM
BluestreamDE
BluestreamDE's Avatar
Originally Posted by ATIX
Car engine lacks power, it feels about 30% performance. (All spark plugs smell like gas)....
My first thought was it might be in Limp Mode. I'd negate your fuel pump as you said you had spark plugs coated in fuel. Sounds like the motor is dumping more fuel then necessary as a safety measure due to something triggering Limp Mode. This is just me throwing my thoughts about the situation.
Old 09-12-2016, 11:50 PM
ATIX
ATIX's Avatar
Arrow
So what would you suggest to attempt next?
Check fuel pressure
Bad fuel?
Thanks for the info I talked to my cousin and he also told me to check the fuel pressure, and most likely he said it's going to be the fuel pressure regulator going out that's gassing the spark plugs. I'm still in doubt and I hope that's really the problem.
Also last fuel I used was 76 Premium and previously I added a Seafoam into the tank to clean the car.
Old 09-13-2016, 05:46 PM
ATIX
ATIX's Avatar
Okay so I talked to another cousin that knows 2 other mechanics, one of them is an expert and Confirmed to replace the fuel pressure regulator.
I searched everywhere on the internet including the forum and there isn't information on testing for fuel pressure. It seems that I have to buy an extension that connects to the stock fuel rail for connecting the gauge =\
phelannz
09-16-2016 04:08 PM
theGentlemenZ
09-11-2016 12:32 PM
Cbryant2111
09-03-2016 08:37 AM
Boba
09-01-2016 08:14 AM
Milosis
08-24-2016 04:14 AM
Quick Reply: Loss of Power, wet spark plugs with fuel P0300
