Center gauge cluster not working
Old May 7, 2017 | 05:46 PM
stevensasuga's Avatar
stevensasuga
Default Center gauge cluster not working
Hi I have a 03 and just recently hit 250k miles. Just today my left gauge in the center cluster stopped working. It was blank and I couldn't scroll throw the options. The oil and volt gauge were working but only for about 10 min then they went out too. Everything else works radio, interior lights , etc. I had no radio work done I do have aftermarket radio though. If you know anything helpful please let me know thanks.
Old May 7, 2017 | 06:22 PM
dcains's Avatar
dcains
Basic trouble shooting, which only you can do. Pull off the waterfall and check all the connections, look at your fuses, etc. A good used set of gauges, if they've failed, is maybe $30 on eBay. I might even have them handy, so you don't have to take it apart twice.
Old May 7, 2017 | 06:43 PM
jhc's Avatar
jhc
General & Tech Moderator
^^^ What Dean said, ck your fuses 1st.
Old May 16, 2017 | 01:46 AM
g3rard's Avatar
g3rard
Try to disconnect the battery for a while also.
Old Jun 17, 2017 | 02:25 AM
NZT-48's Avatar
NZT-48
When I had a my cluster gauge turn off ( no speedo, tach, fuel, temp, and that left pod that shows the tire pressure) I just needed to disconnect the battery. If you reconnect the negative too soon, it won't fix it. 30 minutes isn't enough. I left that negative off over the weekend, reconnected, and it fixed it. The brain just needed a reset. There's even a South Park episode on this.
Old Jun 17, 2017 | 02:38 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
check the connector in the back. Its on the drivers side. youll have to pull the water fall out at the top..not hard to do.
Old Sep 6, 2020 | 01:01 PM
BartmanEH's Avatar
BartmanEH
Another thread with no conclusion. What was the problem in the end? What fixed it?
Old Feb 23, 2024 | 02:46 AM
Marco'sZ350's Avatar
Marco'sZ350
No real information on this issue so i tell you how i fixed my problem..after checking all fuses and all of them was good..i check the connector in the back of the three gauges. Its on the drivers side. youll have to pull the water fall trim bezel out at the top just enough to see the connector ..be careful! ..the bottom still screwed in so don't pull back too far ..not hard to do. Now it was easier for me Not to be sitting, but rather reaching from driver side unplug connector with car running and plug it back in and all gauges came back to life! Push bezel trim back in place and done..hope this helps some one
Old May 15, 2024 | 05:18 PM
brysonmartin's Avatar
brysonmartin
I’m currently having a problem like this on my z, were all of your gauges and lights out above the steering wheel too?
