Sitting Z for couple months, no oil
So I had my Z sitting for couple months (probably 2). Before it sat, the oil was full. I finally got it together an started it up this morning, notice the oil was at the low mark on the dip stick.
i know that the DE's burned oil but I'm not sure if the HR's do. Has anyone come across an issue like this? Is there anything else that needs to be checked before driving it again?
zakmartin (08-23-2017)
At first i was speechless, Then I thought this qualifies for some type of award.
Obviously if the car wasn't running, it wouldn't burn any oil 🙄. I was thinking while I was running it before it sat, maybe it was burning oil an I wasn't awear. I just find it odd that it had oil cause I had changed it bout 4 months before it sat for another 2 month. An now I checked an it's on low.
The car is show room clean with no leaks and low mileage. Just a weekend car. The battery was dead but nothing a quick charge couldn't handle.
HR's aren't known to burn oil like the DE's right?
Obviously if the car wasn't running, it wouldn't burn any oil ��. I was thinking while I was running it before it sat, maybe it was burning oil an I wasn't awear. I just find it odd that it had oil cause I had changed it bout 4 months before it sat for another 2 month. An now I checked an it's on low.
Now you say, "I had changed it bout 4 months before it sat "...
So you haven't checked your oil in 4 + 2 months? -no mention of how many miles you put on it in the four months! Come on man, wth. Do you really think anyone here can help you with the info supplied?
If you had it done, did you check it to make sure it was topped up properly??
See what I'm sayin?... No info - NONE
You have raised the bar on stupid first posts, my friend.
You said, "Before it sat, the oil was full."...
So u change your oil an never check it till your next oil change? Didn't I mention that I checked it an It was full before it sat
Are there any adults on this forum or are u just all a bunch of small minded children with your egos so far up your asses
You said...
"I was thinking while I was running it before it sat, maybe it was burning oil an I wasn't awear."
Anywho, if you haven't changed your oil in 6 months, why not change it now and monitor the consumption?
- good luck. Over and out
You really want to know if your car is burning oil after sitting still for two months? Then the answer is NO.
Last edited by zakmartin; 08-24-2017 at 09:12 AM. Reason: Emphasized "NO" so that OP could understand that is the correct, COMMON SENSE answer.
Theminatar (08-25-2017)
Yep, the DE is frustrating trying to check the oil and you're never 100% confident till it gets a bit dirty.
350Z/370Z Tech Moderator
Always full!
Disclaimer: Please don't anyone take that seriously, I won't be liable for a stupidity induced bearing failure.
Yay! You learned something. You get a blue star.
