Clicking noise in Engine
Old Dec 8, 2017 | 09:40 AM
teenage warhead's Avatar
teenage warhead
Default Clicking noise in Engine
Hi,
So I've barely started to hear this noise under my hood, It's a clicking noise coming from I think the engine maybe the chain. Unsure, video helps understand the sound a little more..
Sounds similar to this..
2006 350z touring
Mods: full intake, coilovers nothing major..
104.5k Miles in..
New to the scene..
Old Dec 8, 2017 | 09:46 AM
BluestreamDE's Avatar
BluestreamDE
Link don't work and that ticking can be anything with the little info you told us. Best thing I'd do is bring it to a reputable shop to diagnose the car.
Old Dec 8, 2017 | 09:49 AM
teenage warhead
Does it work now? Not sure how to make it work.
Old Dec 8, 2017 | 09:56 AM
BluestreamDE
It works now, you are fine. I wouldn't worry about it very much, VQs run pretty noisy anyway. But to be safe I would bring it to a mechanic to diagnose for sure.
Old Dec 8, 2017 | 09:57 AM
teenage warhead
Alright, just wanted to make sure it's nothing to major..
Old Dec 8, 2017 | 10:02 AM
BluestreamDE
Np, also some advice, make sure to run 91 octane or higher fuel on these cars if you aren't doing so already, as they are pretty high compression. Better fuel will make the car run smoother.
Old Dec 8, 2017 | 11:01 AM
teenage warhead
Correct I am,
I'm a bit late on maintenance stuff. Might killed my stuff cause of that too..
Old Dec 8, 2017 | 02:01 PM
zakmartin's Avatar
zakmartin
Probe the engine with an automotive stethoscope (they're dirt cheap) to try to pinpoint where the noise is coming from while the engine's idling.
Old Dec 8, 2017 | 04:50 PM
teenage warhead
I've actually kinda tried, It's coming from the actual engine bay.. and not the timing's..
Old Dec 9, 2017 | 11:07 PM
Cavemanz33's Avatar
Cavemanz33
Have you ruled out the top ends as the source of the noise? Right now I'm thinking the valves are causing that noise?
Bryaannnt
Aug 16, 2019 12:00 PM
OdesiTT
Oct 20, 2017 03:09 PM
The_Ghost
Oct 10, 2017 12:20 PM
grimlev
Sep 26, 2017 04:12 AM
irbullet
Sep 19, 2017 10:45 AM
