squealing then overheating
Old Dec 10, 2017 | 09:21 PM
Antbrad9960's Avatar
Antbrad9960
Default squealing then overheating
Ok so i was leaving the gym, and on my way back i did a quick pull on the highway and everything was fine. Was pulling down my street and my car made a very loud squealing noise and the the temp started to rise. Not sure if this is common as im not very knowledgeable about cars and haven't had my Z for very long. And suggestions?
Old Dec 11, 2017 | 03:36 AM
travlee's Avatar
travlee
Master
check the belts
Old Dec 11, 2017 | 05:20 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Sounds like your water pump. Did the squealing then go away, or it stayed?..
Old Dec 11, 2017 | 06:47 AM
Antbrad9960
Wen I start the car the squealing starts. And then it randomly does it sometimes.
Old Dec 11, 2017 | 07:18 AM
Atreyu'z 350
OK. Sometimes. This all just happened after that pull, right? No squealing before then?.. Was it raining? Were your belts wet by any chance?.. Just trying to narrow down the scenario.
Old Dec 11, 2017 | 07:28 AM
Antbrad9960
It would always squeal when I started the car. I always thought it was my a.c. belt. And no it wasn' raining. Just now went out to my car and checked the coolant level and it' was extremey low. Not seeing any leaks.
Old Dec 11, 2017 | 08:14 AM
Atreyu'z 350
Oh. Ok. Well then that makes me think it's one of your belts then like trav said. Did you check them to see if they're loose or worn out(cracked or frayed). Probably just need to be tightened a bit. As far as your coolant issue, I would just fill it to the max line and see if it runs hot again. If it does, and the belts are up to par with no squeaking, I'd suspect a sticking thermostat.. But for now, just check the tightness of your belts and top off with coolant.
Old Dec 11, 2017 | 08:19 AM
Antbrad9960
Yea so my serpentine belt is starting to tear. Just picked up a new one. Filled the coolant up and I'll just wait like you said. Appreciate the help!
Old Dec 11, 2017 | 08:54 AM
jhc's Avatar
jhc
General & Tech Moderator
Might replace the radiator cap while you're at it. The coolant had to escape from somewhere.
Old Dec 11, 2017 | 08:55 AM
travlee's Avatar
travlee
Master
woot.... i called it
Old Dec 11, 2017 | 09:10 AM
Atreyu'z 350
...Know-it-all.
Old Dec 11, 2017 | 09:11 AM
travlee's Avatar
travlee
Master
Old Dec 11, 2017 | 10:26 AM
Atreyu'z 350
lol.. you know he gets the ladies
Old Dec 11, 2017 | 10:27 AM
travlee's Avatar
travlee
Master
true.... with my sick dancing skills. rare unseen footage of me
Old Dec 11, 2017 | 11:04 AM
Atreyu'z 350
lol.. NOW I understand why you got the Corvette.
alford
Jul 29, 2008 01:06 PM
raymanZ
Jun 2, 2003 07:19 PM
djbit
Mar 12, 2003 10:01 PM
