Click Noise from rear
Old Jul 1, 2018 | 10:51 AM
Bernardo Z33's Avatar
Bernardo Z33
Default Click Noise from rear
Hello everyone. Before I start yes I've searched everywhere and have done research on this. Anyways recently I changed all my brake rotors and pads and it turned out my rear wheel bearing was super shot. I took my sweet time doing brakes and changing the wheels bearing and made sure to torque everything to spec nice and neat. The only thing however I didn't torque all the way was the axle nut. Torque wrench goes to 150 then used a breaker bar and went a tiny bit more. Not a lot. And yes I greased up the axle very very good. Litteraly 2 days later I get this CLICK from the side I changed the wheel bearing. Would it be my axle nut not tightened to 177?because I swear it isn't the grease as I added a good amount on the right area. The click only happens when taking off 1st gear or reverse. It honestly doesent bother me but if it's a severe problem please tell me. Thank you fellas and have a happy 4th!
Old Jul 1, 2018 | 01:44 PM
mr. sparco's Avatar
mr. sparco
Did you adjust the parking brake? Two ways to adjust it: interior handle and exterior on the rotor. I had a slight click squeal once I got up to speed. The new rotors made very slight contact with the parking brake shoes.
Old Jul 1, 2018 | 03:09 PM
Bernardo Z33
yup sure did. Adjusted the handle to 6 to 7 clicks and tightened the braking shoes until all tight and then loosened 6 to 7 noches. It's like a click once I barely move forward or backwards.
Old Jul 2, 2018 | 02:05 PM
Bernardo Z33
Anyone please I need some help friends
Old Jul 3, 2018 | 09:37 AM
travlee's Avatar
travlee
Master
sounds like the axle click, but since you greased them hard to say.
Old Jul 3, 2018 | 09:47 AM
guitman32's Avatar
guitman32
Check your end links.
An improperly torqued wheel nut can loosen and cause the bearing to make noise, but you can easily verify the torque on the nut to check.
If you didnt use the correct grease or similar when lubing the axle splines and face, the axle tick could come back relatively quickly (FSM calls for M77 molykote).
Old Jul 3, 2018 | 10:21 AM
Bernardo Z33
I got the grease and parts directly from Nissan. It's was the one from the manual. Now I'm guessing it is the wheel bearing nut. Do you know what the easiest way to tighten it without the axle turning would be?
Old Jul 3, 2018 | 12:27 PM
guitman32's Avatar
guitman32
Since you already have some initial torque on the nut...pull the ebrake hard, bolt on your wheels/tires. Lower the car onto the tires just enough to get a decent amount of friction on the ground and you should have no problem getting to 200.
Old Jul 3, 2018 | 05:40 PM
Bernardo Z33
Thank you for the help!! Also getting to 177 not 200 right? Anywho if that doesent fix the click is it okay to go with it without fixing It? I don't mind the noise as it doesent bother. If it's not dangerous or anything is It okay for me to leave it alone?
Old Jul 3, 2018 | 07:03 PM
guitman32's Avatar
guitman32
The FSM calls for a range, ive usually gone to the upper end of it. Dont remember the exact number but it shouldnt be that critical.
If a wheel bearing is making noise it is going to go sooner than later. That being said based on what you have posted im not convinced its your wheel bearing.
However, when you run the Z for a while with a significantly under torqued axle nut, the bearing develops a large amount of play that almost always destroys it. It may or may not make any noise. You may be able to cinch it up again, but there is probably damage that will lead to premature failure. If you tracked your car you would definitely notice that hub running hot.
Old Jul 4, 2018 | 05:42 AM
Bernardo Z33
luckily I don't track the car just daily it. I'm going to get a torque wrench and torque it to 177. I've only drove it like a few couple of times after the bearing change so I don't think there's damage. If I tighten the bearing all the way and still hear it can I just let it be?
Old Jul 4, 2018 | 06:58 PM
guitman32's Avatar
guitman32
Only you can make that decision...unless the axle nut got so loose to introduce play in the bearing you are probably fine. And if you got it to at least 150 im almost sure it hasnt loosened up and the issue is something else.
Old Jul 9, 2018 | 11:38 AM
Bernardo Z33
Here is a update my friend you were right! I took the wheel off and checked and the grease was still there perfectly fine all lubed up. Grabbed the torque wrench that only goes to 150ft lbs to check if the nut was at least at 150ft lbs. It was so I just grabbed my huge breaker bar and gave it a strong turn.. It only went about 1/4 of a turn more until I couldn't budge it. Drove the car and no more click!!
Old Jul 9, 2018 | 04:20 PM
guitman32's Avatar
guitman32
Awesome, Im glad you got it! Nice work!
Z33E
Sep 23, 2016 09:10 PM
bmcmvox
Nov 19, 2012 08:23 PM
imonlykidden
South East
43
Nov 25, 2008 07:32 AM
NX ZR
Jul 24, 2007 01:08 AM
