Brake Lights not working. Seeking help
Old Aug 4, 2018 | 07:34 PM
Siqcology's Avatar
Siqcology
Default Brake Lights not working. Seeking help
Hey guys,
Car ; 2007 350z LED Taillights (brembo conversion )
i just came to a dead end and can’t decide what’s wrong with the issue.
All my lights work. Rear tail lights and headlights. Normally.
I recently came across where when I hit the brakes I don’t see my stop lamps light up. I went as far as
swapping tail lights with someone (nothing)
using my tail lights on my friends car (works fine)
Using his brake switch (worked on his car not mine)
using my brake switch on his car (worked on his car not mine)
checking for shorts in the tail lights and checking grounds.
All fuses are good on all 3.
Replace FULL fuse box behind engine
My question is. Is there a relay or something or what else can I do? Most people have the switch problem but mine seems to be deeper. The only thing I know is that my rotors are warped but that wouldn’t cause my car to not illiminate the stopping lamps as they use too.
Old Aug 5, 2018 | 09:29 PM
mr. sparco's Avatar
mr. sparco
Did you check for wiring continuity at all connecting points?
Old Aug 6, 2018 | 04:49 PM
Siqcology's Avatar
Siqcology
i know nothing about electrical wiring. I do have a voltmeter from Walmart. A cheap 12 dollar one. Now to check this. I can just stick the voltmeter into the open connector after taking out the headlight connector right? And if there I power and all fuses are fine. What would be next?
Old Aug 7, 2018 | 08:34 PM
mr. sparco's Avatar
mr. sparco
Check the harness at the tail lights on the body side to see if there is power. I would test all pins to be sure each is live.
Old Aug 9, 2018 | 10:22 PM
Siqcology's Avatar
Siqcology
update- the wire was disconnected from the connector, wasnt really but in the connector it was loose. Use a volt meter and traced it down!
hologrvm
Jan 5, 2017 05:18 AM
cgkp0925
Mar 2, 2016 12:36 PM
Dr.Paulyy
Jun 8, 2014 05:11 PM
nick731
Jun 12, 2012 09:56 AM
Z33hr6spd
Dec 9, 2009 06:13 PM
