Clicking sound from window switch new switch and motor
Old Mar 27, 2019 | 07:23 PM
iloveherlogic's Avatar
iloveherlogic
Default Clicking sound from window switch new switch and motor
Hi everybody I have read through quite a few forums and threads looking for this issue but havent been able to resolve my issue.
My driverside window switch makes a continuous clocking sound when trying to pull up or down the driver window. The passenger side still works. I originally thought it was the window motor. I replaced it and the issue was not resolved. I installed a new switch. Still no luck. I thought perhaps I got a bad refurbished motor so I exchanged it. Still doesnt work. I have had it plugged in and not attached to the regulator and the motor doesnt spin just a clicking noise. I do feel slight vibrations while holding the motor though. The key in door does not pull the window down nor does the key fob.
Any help is appreciated.
Old Dec 1, 2020 | 01:43 PM
Raul Roa's Avatar
Raul Roa
i have the same issue and have done the same. Can’t figure it out myself. If you figure it out before me let me know. And if I. Find out I’ll let you know
Old Mar 20, 2023 | 04:59 PM
Cayd9299's Avatar
Cayd9299
Did you ever find a solution? Dealing with the same problem.
Old Mar 22, 2023 | 02:31 PM
Cayd9299's Avatar
Cayd9299
Did you ever solve this? Dealing with the same problem and haven’t found anything helpful to fix it.
Ken_s_Wood
Oct 15, 2014 01:02 PM
Z_on_TE37's
May 7, 2013 02:41 PM
Joepiper151
Jun 4, 2011 06:26 AM
Junkster
Apr 30, 2011 03:43 PM
ladyZ1311
Mar 29, 2011 02:52 PM
