PSI light keeps flashing
My psi light keeps flashing in my 03 350z , I believe it’s a sensor that isn’t working properly . Do any of you guys know what that sensor is called and where can I buy it ?
It's a common probably ESPECIALLY with all Nissan's that include tpms sensors instead of running off of ABS, mine does the same, I just ignore it. As long as you keep an eye on you're tire pressure you'll be fine. If it bothers you that much take it into a shop and have them replace the bad sensors
