Cam sensors Nissan OEM is Hitachi and how to test sensors
Old Aug 16, 2019 | 08:49 AM
Bill Zeek's Avatar
Bill Zeek
Default Cam sensors Nissan OEM is Hitachi and how to test sensors
This is helpful so you don't waste money on cheap after market sensors.
I had code P0340 and P1078 and when I started reading about the after market sensor that don't seem to last I tracked down the OEM supplier as Hitachi. I called Hitachi and spoke to a tech support who confirmed that Hitachi supplies Nissan's sensors.
The Nissan p/n 23731-AL61A angled connector is Hitachi p/n CPS0005
the Nissan p/n 23731-6J90B straight connector is Hitachi p/n CPS0008
Using the Hitachi p/n you can find the sensors for under $50/each
You can go to
https://www.hitachi-automotive.us/do...icaCatalog.pdf
for a download of Hitachi's catalog sorted by vehicle make and model.
NOTE This is the link to the current catalog, when I first posted this I had a link to a 2017 catalog. If you look at both catalogs there is a difference in the Hitachi P/Ns for both camshaft sensors. I don't know why but I do know that my 2006 has the CPS0005 & CPS0008 and those are the parts I used. Here is Hitachi's contact info if you have any questions.
Hitachi Automotive Systems Americas, Inc.
6200 Gateway Drive, Cypress, CA 90630
Tel: 949-471-3500 Fax: 949-471-3522
NOTE: when you go to the link it may open a new browser with a blank page but the catalog SHOULD be in your download folder
Hitachi p/n CPS0005 angled sensor = Nissan 23731-AL61A driver side intake and passenger side exhaust (angled sensor)
Hitachi p/n CPS0008 straight sensor = Nissan 23731-6J90B driver side exhaust and passenger side intake (straight sensor)
New sensor readings are the same for both, because it the same sensor electrically but the connector is either straight or angled.
FLUKE model 87 (this is a better quality meter that has been calibrated)
(+) (-) meter leads
PIN numbers are left to right looking into the sensor connector NOT the wire harness connector
1-2 = 90K these are readings for new sensors
2-1 = 96K
1-3 = 90K
3-1 = 95K
2-3 = 1.2k
3-2 = 1.2k
My bad sensors read between 1.2K ohms and 15 meg ohms
Last edited by Bill Zeek; Aug 17, 2019 at 04:46 AM. Reason: corrected the link to Hitachi catalog see red text for details and added Hitachi phone number
Old Aug 16, 2019 | 03:12 PM
jellofuel's Avatar
jellofuel
Good info! Thanks for sharing
Old Aug 16, 2019 | 03:33 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Agreed! ^^^
Old Aug 16, 2019 | 07:47 PM
jv350z's Avatar
jv350z
thank you good sir!
Old Aug 20, 2019 | 07:36 PM
bealljk's Avatar
bealljk
Hat tip and subscribed when mine go out!!
Alston518
Dec 23, 2014 08:38 AM
jdr63420
Jul 21, 2014 07:07 PM
Spike100
Mar 14, 2014 03:17 PM
ProChargedZR
May 9, 2013 06:11 PM
nick731
Jun 6, 2012 10:01 PM
