Wiring harness issue
Old Oct 17, 2019 | 04:57 PM
Codyz33's Avatar
Codyz33
Default Wiring harness issue
I did a motor swap on a 2005 350z non rev up, put a 03 motor with 03 harness with the 05 ECU. Found out I can’t use the 03 ECU due to the upstream o2s being different. My 05 engine harness is missing a downstream oxygen sensor is there anyway around this? I tried to put the 03 ECU In the 05 car and the immobilizer comes on... don’t know what to do from here but buy another harness?
Old Oct 17, 2019 | 05:13 PM
bealljk's Avatar
bealljk
what do you mean it's missing downstream O2 sensors? is it missing a sub-harness?
Old Oct 17, 2019 | 05:37 PM
Codyz33's Avatar
Codyz33
No, here’s another picture it’s missing the actual other side of the o2 sensor in the wiring harness that goes down along the transmisson
in in the first picture u can see bank 1 and bank 2 connector
second picture has only bank 1 I’m assuming somebody ripped the other side off for some reason
Old Oct 17, 2019 | 05:39 PM
bealljk's Avatar
bealljk
do you mean the passenger side or driver side? or the sensor connector? did it get cut off?
Can you take a good picture of the entire harness?
Old Oct 17, 2019 | 05:42 PM
Codyz33's Avatar
Codyz33
Not sure how it happened and not sure what side I just know it’s missing one downstream sensor so there’s nothing to plug in bank 2
Old Oct 17, 2019 | 05:43 PM
bealljk's Avatar
bealljk
It probably got clipped off ... look for 4 bare wires in that area, it'll be right near the one still in-tact.
I have a few of those pig-tails if you need a replacement. Shoot me a message.
Old Oct 17, 2019 | 05:59 PM
Codyz33's Avatar
Codyz33
Heres a better look I think the gray connecter is the other side but it’s broken Any ideas for repairs
Old Oct 17, 2019 | 06:14 PM
bealljk's Avatar
bealljk
you need to de-pin & repin to a good connector or splice in a good connector.
I have a bunch of those if you need one -
g-reddy
May 6, 2009 12:17 AM
kevin8086
Jan 2, 2009 03:00 PM
youngmanzy
Jul 24, 2008 06:59 AM
cjb80
Jun 29, 2005 12:24 PM
