No high or low beam on driver side
Old Dec 31, 2019 | 10:40 AM
johnsal's Avatar
johnsal
Default No high or low beam on driver side
My 2007 driver side headlight stopped working. It had been raining so I'd hoped it needed to dry out due to moisture, but no luck. My wheel well liners were in bad shape when I got the car 6 years ago, and I haven't replaced them.
I see there are separate fuses for high and low beam on each side. Are the relays for each side of the lights also in the fuse box behind the battery? Which one is for the driver side?
As for testing the ballast, I don't have a high voltage probe, so what is the easiest way to check that it has 12 volts on the input? How do I get access to the ballast?
Old Dec 31, 2019 | 10:53 AM
travlee's Avatar
travlee
Master
swap em from side to side... its prob toast from water getting on it
Old Jan 1, 2020 | 11:54 AM
Spike100's Avatar
Spike100
I had to replace the Headlight Control Module. This part was ruined when my fender liner was loose and the headlight assembly filled with water thrown up by the front tire.
Old Jan 2, 2020 | 02:53 PM
SPID3R's Avatar
SPID3R
They say you can clean out and dry the ballast and it will work again.
however, if both high and low are not operating it may be as simple as a fuse on the high beam.
maui1girl
Jun 24, 2018 11:19 AM
KTR5
Nov 3, 2013 09:01 PM
Colourdeaf
May 5, 2012 10:02 PM
kihun
Apr 23, 2011 02:16 PM
ecorona6
Feb 4, 2006 08:53 PM
