Squeaky belt/pully
Old Mar 21, 2020 | 12:23 PM
gwhelps's Avatar
gwhelps
Default Squeaky belt/pully
Hey,
Trying to diagnose a squeak! Changed the drive and AC belt and got a squeaking after the new belts were installed. Only happens when the wheel is full lock and the AC is on. I've adjusted the tension on both belts, and greased the AC compressor clutch, still squeaks!
Old Mar 21, 2020 | 01:25 PM
jhc's Avatar
jhc
General & Tech Moderator
Originally Posted by gwhelps
Hey,
Hello and welcome,
Really not sure what you mean by "greased AC compressor clutch" as lubrication is entirely internal. A small "squeak" when the steering wheel reaches it's limit is normal. Might want to get someone with more experience to take a look, GL!
Old Mar 21, 2020 | 02:09 PM
gwhelps's Avatar
gwhelps
Originally Posted by jhc
Hello and welcome,
100% need to have more experienced eyes on it! The squeak, isn't just a regular full lock noise. It's a more violent sounding screech but only when AC is on and wheel is being turned. I greased the front part of the AC compressor that moves in and out when using the AC. Just incase it was something simple. Could just be the new belt is **** also. Wasn't doing this before the change. Thanks
Old Mar 21, 2020 | 06:00 PM
jhc's Avatar
jhc
Take a deep breath and realize there is break in/stretch after belts are installed and broken in. Rule in/out oddities, in this case you state only when a/c on. So-
Turn a/c off and turn wheel until locked (when stopped). If the noise continues, tighten main/power steering belt. If not it's likely the a/c belt or perhaps another problem.
Kinda difficult to diagnose problems over keyboards, GL!
Juni0r
Jun 29, 2021 02:01 AM
zyou8er
Jun 1, 2017 08:47 PM
Encino_Man
Oct 19, 2010 10:01 PM
blueVQ
May 26, 2010 03:47 PM
boxsterkiller
Dec 5, 2003 10:29 AM
