Nissan 350z soft top not closing completely
Old Mar 21, 2020 | 05:56 PM
chrisjgye's Avatar
chrisjgye
Default Nissan 350z soft top not closing completely
I recently got a 350z, but i dont know what is causing this problem
Old Mar 22, 2020 | 10:01 AM
travlee's Avatar
travlee
Master
When did it start, what have you tried....etc etc
Old Mar 22, 2020 | 11:04 AM
jhc's Avatar
jhc
General & Tech Moderator
Looks like it's close enough to yank that puppy down and latch it, looks fully extended, just a bit high. That's what I'd do from the pics.
Old Mar 22, 2020 | 12:49 PM
chrisjgye's Avatar
chrisjgye
It was like that when I bought it, owner said that was because the passenger side window elevator wasn’t working, i already fixed that window but it still like that, it can go all the way down if we push it but it doesn’t seem to reach properly because i cant lock it, also the right apparently is not fitting the hole
Old Mar 22, 2020 | 04:10 PM
jhc's Avatar
jhc
Help me to understand. Are you saying you bought this car knowing the top doesn't close properly and you cannot drive it in the rain?????
Old Mar 22, 2020 | 04:56 PM
bboypuertoroc's Avatar
bboypuertoroc
Obviously the dude bullsh!tted you. Check to make sure the motors are good. Something in here might help as well. Check the service bulletins for the soft top - https://my350z.com/forum/350z-roadst...ulletin-s.html
... also the right apparently is not fitting the hole
If no fit use spit.
Old Dec 29, 2020 | 12:32 PM
jarek1111's Avatar
jarek1111
sorry
Old Jan 5, 2022 | 07:10 PM
dakota.marion's Avatar
dakota.marion
Default I know the cause of the problem but not the solution.
One day I was going down the highway and the wind got between my top and the top of my windshield, the latching hooks must have not been engaged and the top almost came off my car. Unfortunately I have not found a way to fix this. That is why I am here. the same problem I have is the same problem you have the previous owner lied to you.
Old Jan 5, 2022 | 07:18 PM
travlee's Avatar
travlee
Master
You can't fix it.....the assembly needs to be replaced
Old Jan 8, 2022 | 02:39 PM
bboypuertoroc
I bet the top is still open on OP's car.
emdace
Nov 5, 2010 05:43 AM
sweetcarz02
Drift
Jul 28, 2009 01:09 AM
SolarOrange350
Jun 12, 2008 08:27 PM
Whitey#1
Apr 10, 2008 08:16 AM
