Nissan 350z ac problems
Old Jul 14, 2020 | 12:21 PM
damiana1's Avatar
damiana1
Default Nissan 350z ac problems
My air conditioning in my 06 350z blows out hot air I tried to recharge it but it said it was over full so I let some out and its in the green now and its still blowing hot i checked the in cabin air temp sensor and cleaned it off it seems to be OK what else can I try. It blows hot like hotter than outside air
Old Jul 16, 2020 | 12:56 PM
calvin.w's Avatar
calvin.w
Yeah it's basically blowing engine bay air in your face.
You could have a bad pressure switch. It's located on the dryer on the condenser. It just screws in and plugs in, pretty simple fix. But if you take it out, make sure you relieve all pressure before doing so. I learned that the hard way.
You'll also have to have it vacuumed and recharged after taking the switch out since you'll be welcoming air into the system.
Old Sep 25, 2020 | 02:59 PM
damiana1's Avatar
damiana1
I was messing with it and the clutch engages and spins the compressor but it doesn't feel like it has any compression
Old Sep 27, 2020 | 05:49 PM
calvin.w's Avatar
calvin.w
Are you sure it's the clutch spinning and not the compressor pulley?
May have to take it to be vacuumed if the clutch kicks in and it's still hot
Old Oct 1, 2020 | 06:09 AM
damiana1's Avatar
damiana1
Its definitely spinning the clutch and is engaging properly i also have the refrigerant at the proper pressure i think my compressor is just bad
Old Oct 1, 2020 | 04:37 PM
calvin.w's Avatar
calvin.w
Ok so have you removed the lines at all or the pressure sensor switch?
alienx
Oct 31, 2022 10:41 AM
brooklyn
Oct 1, 2017 06:13 PM
fuzzy_dba
Sep 10, 2008 10:34 PM
siznimper
Aug 27, 2005 02:01 AM
fanatic
Sep 25, 2003 11:23 AM
