Cooling fan issue
Old Sep 21, 2020 | 03:53 PM
Sean Chipman's Avatar
Sean Chipman
Default Cooling fan issue
So ive got a 2003 350z and ive been chasing a cooling issue, heat works good, fans do not seem to be coming on, dod the IPDM self test and the fans worked but im still having the issue, i dont see them come on even when temps start getting high, everything is fine unless im stopped in traffic for a while or sitting at idle for a while, any suggestions?
Old Sep 27, 2020 | 06:09 PM
calvin.w's Avatar
calvin.w
So just to verify, you checked the relays?
Old Sep 28, 2020 | 02:26 AM
Sean Chipman
yeah i did, replaced all 3 relays.
Old Sep 28, 2020 | 02:57 PM
calvin.w's Avatar
calvin.w
Hold on I had to re-read the original post a few times. Are the fans working or no?
Old Sep 28, 2020 | 03:14 PM
JCat's Avatar
JCat
Do the fans turn on when controls are set to A/C ?
Old Sep 28, 2020 | 03:27 PM
Sean Chipman
if i manually activate the relay or do the IPDM self test the fans will come on however at an idle or slow speeds the fans will not kick on by themselves. All Relays are new and working fine.
Old Sep 28, 2020 | 03:28 PM
Sean Chipman
no they do not, however there is not currently an A/C compressor Hooked up
Old Sep 28, 2020 | 05:31 PM
calvin.w's Avatar
calvin.w
You're talking about the radiator fans right? They have nothing to do with the ac.
If the fans are functional, but don't come on when the water is at a certain temp like they should, it's most likely a sensor issue. There's a sensor that tracks the water temps and when it gets a certain degree, it tells the fans to kick on.
Old Sep 29, 2020 | 05:04 AM
JCat's Avatar
JCat
The radiator fans come on when we turn on the A/C. I suggested this test to see if they actually turn on and function.
Old Sep 29, 2020 | 01:31 PM
calvin.w's Avatar
calvin.w
They should turn on when the car is at low speeds or parked for a while, only after everything is heated up to operating temps.
usafmarker
Sep 14, 2016 04:53 AM
Xrabbix
Jul 19, 2016 07:26 PM
2alien10p
Mar 9, 2015 01:47 PM
vagel72
Aug 26, 2013 01:25 PM
SirMichael
Jun 24, 2013 07:31 AM
